Bub,
The nozzles I run are CP flat fans on a carousel that have three tips installed. We generally target about 40-50 pounds of boom pressure overall no matter the rate. My small tips give me about two gallons per acre all on @ 40#'s. So they will give me close to three @50#'s. My middle tips give me 5 gallons per acre @40#'s. and my large tips give me 7 gallons per acre @38#'s. All those rates are at a 60' swath. If I want ten gallons I narrow up to 50' swath and run about 52#'s of pressure with the large tips.
Those are the common rates 2, 3, 5, 7, and 10 gallons per acre. I can turn some off or mix and match if I need some middle rate while maintaining proper boom pressure.
Calibration is easier than ever with the flow control. I just tell it how wide of a swath and how much total volume per acre I want. I put in the total amount loaded and just push the handle down. It counts down the gallons sprayed, and makes small adjustments to the boom pressure to maintain a constant rate per acre no matter my changes in groundspeed (it is slaved to my GPS).
JRStripe,
Productivity in ag as you know from running a tractor is dependent on type of work, weight of material when seeding or fertilizing, how many acres per load, field size, and ferry distance. The 802 is quite productive overall as you may imagine, and even lethal when in close on good running.
My personal operations with that aircraft cosisted of pine tree fertilization (all dry, lots of ferrying) and row crop work in Arkansas, mostly rice (full variety of both high and mid volume dry fertilizers, and high and mid volume liquid spraying.
I think my average in rice was around 180-220 acres per hour spraying 5 gallon work (usually 750 gallons or 150 acre loads). My high was around 320 acres an hour on mile runs of five gallon work within three miles of the strip.
Fertilizing with urea we hauled around 4,500# loads and it mostly went out at 100# per acre. So if in close we could do 4 loads an hour that would be the same, about 180 acres an hour. If ferrying and down to 2-3 loads an hour it would be more like 100 acres an hour.
Potash or Sulphate can get around 60-85 pounds per cube so if you have the runway you can pack around 7,500#-8,500# loads. That pays off when ferrying due to the reduced amount of total loads to haul.
Most pine fertilizing is urea at 386#'s per acre, so 4,500#'s only goes about 12 acres per load. LOTS of loads even in the 802. It was reallly monotinous in the 400 gallon turbine Ag-Cats doing 6 acres per load! Usually with the ferrying in timber we did 2-3 loads per hour, sometimes less when ferrying outside of 20 miles.
There are some links on my site,
http://www.cropjet.com, you may like.
Hope this provides some insight for you.
