Backcountry Pilot • High res sectional chart images
14 postsPage 1 of 1
http://aeronav.faa.gov/index.asp?xml=aeronav/applications/VFR/chartlist_sect
This is probably common knowledge, and using something like Skyvector gets you a portal-style viewer, but sometimes I like to open the entire sectional as an image on my giant 30" monitor and just poke around.
Scroll down the page to see a list of links for each sectional. The files are large...60MB uncompressed TIFF.
Re: High res sectional chart images
NERD
Actually, that's pretty cool. I had no idea you could just get the FAA sectional online. Nice find Z
Even on a 24" monitor.
Wonderful. Thanks.
rjb offline
Guessing that's where apps like Skycharts Pro pull the chart data?
Vick offline
Solum Volamus
Vick wrote:Guessing that's where apps like Skycharts Pro pull the chart data?
I'm thinking yes. Don't tell FlightPrep.
Found this while catching up on...certain lawsuit-oriented news:
http://vfrmap.com/
15" screen, direct reverse proportion to you unit! :roll:
FloatFlyer offline
The VFRMap site is great! Does it open where you are too? It loaded right where I am and I was wondering if it opens where you guys are too?
Jaerl offline
Jaerl wrote:The VFRMap site is great! Does it open where you are too? It loaded right where I am and I was wondering if it opens where you guys are too?
Totally. Your location can be approximated based on your IP address, which the web server receives when you make a request.
That's scary! Guess I better quit sending letters to the White House. :shock:
Really, I had an address for the White house for a while and I used to send GB, Hillary jokes. :D
Jaerl offline
I like using the sectional chart feature on duat.com, you can enter your route of flight and it will show it on the map. There is also several weather overlays you can display on the map.
Which explains why it won't open over here in paradise.
porterjet offline
KSBP
Is there is a site to look at or download Canada's VFR charts?
Ipad USA sectionals = $75
Canada = $225
Freedom isn't free.
wyomingiswindy offline
Jaerl wrote:That's scary! Guess I better quit sending letters to the White House. :shock:
Hmm, you think you have Drones flying over your house? :shock:
14 postsPage 1 of 1
Users browsing this forum: dabridgham and 1 guest
