mtv wrote:in your previous post you noted being pissed because you were routed over a seaplane Fly In, with no notice in your brief. So, the domestic infrastructure is “designed to provide sanitized airspace with deconfliction procedures where there is a chance of traffic conflict”?
mtv wrote:I can show you where regularly used MTRs cross major and heavily used mountain passes perpendicular to the flow of GA traffic, and there is no way for GA pilots to know whether these routes are hot or not. Other than see and avoid, there’s no way for the military aviators to know if a GA airplane is coming through the pass. And there are similar examples on many MTRs.
The “deconfliction procedures” are in fact largely “little airplane, big sky”. And, that works most of the time.....
Vick wrote:mtv wrote:I can show you where regularly used MTRs cross major and heavily used mountain passes perpendicular to the flow of GA traffic, and there is no way for GA pilots to know whether these routes are hot or not. Other than see and avoid, there’s no way for the military aviators to know if a GA airplane is coming through the pass. And there are similar examples on many MTRs.
For MTRs, GA pilots can find out if a route is scheduled for use or active from FSS (crews check on and off the route with FSS). I’d wager that almost no one ever does but the information is there for the asking. From the fact that you don’t know that we can infer that none of your students have been taught so. At a minimum identifying where a desired route of flight encounters an MTR means a GA pilot knows where to be extra vigilant for military traffic. It’s true that military crews don’t know where they’ll encounter civilian traffic, but many aircraft have radar and can identify traffic well before it’s a threat and ensure safe separation.
Like most areas of aviation the infrastructure hasn’t kept up with technology. Rather than make a call for a flight brief many now just plug it all into Foreflight and go fly. ADS-B will help but the benefits will only be fully realized if everyone participates. Most MTRs traverse airspace that won’t require ADS-B out, so we can’t assume that all the traffic out there will appear.
Beyond that the best thing a GA pilot can do is study the charts, especially if they’re flying in unfamiliar airspace, and make sure they’re familiar will all SUA along their route. Then give FSS a call in flight for added assurance.
contactflying wrote:While heat and bumps are definitely worse really low, it is truely a big sky at 200' AGL and below. Ultralight, crop duster, and pipeline patrols are few in number. In 17,000 hours, I had very few encounters with other military or civilian aircraft. I expect drones will change that for pipeline in built up areas.
MTV, I respect your views and your opinion, but what has given you the impression that military fixed-wing aviators aren’t supposed to be operating that low? For military aviators, two things determine how low they’re allowed to fly, the airspace they are flying in and their own personal qual based on flight hours and experience. Many IR and VR routes go down to 100’ AGL. AF pilot low altitude minimums are 100’, 300’, and 500’ (in fighters). When flying these routes, military pilots mission plan to avoid known (published) airports by 1500’ and 3 miles, unless published to avoid by a greater distance. It is bad to assume that all fighters can see you all the time, though some have IFF interrogators and the ability to get radar locks down low (auto acquisition modes and back seaters;). I promise they are looking for you, but things happen fast at 300-500 kts ground speed down low. The training is critical as others have pointed out, but I wouldn’t consider it a primary option all the time like it was used in the days of recce fighters.mtv wrote:contactflying wrote:While heat and bumps are definitely worse really low, it is truely a big sky at 200' AGL and below. Ultralight, crop duster, and pipeline patrols are few in number. In 17,000 hours, I had very few encounters with other military or civilian aircraft. I expect drones will change that for pipeline in built up areas.
Perhaps, Jim, but fixed wing military aviators are not supposed to be operating that low either. Not saying they don't on occasion......
And, I spent a LOT of time down there, and so do a lot of other folks. If you want a religious experience sometime, try a takeoff from a remote river gravel bar and meet a C-130 blasting along at very low altitude. Oh, and then the second, the third, and the fourth.....
Vick wrote:Great posts Apollo & Paddles
MTV - you’re mixing terms, MOAs and restricted areas aren’t the same thing and have different implications for VFR traffic. There’s nothing that stops a VFR aircraft from flying through a MOA without talking to anyone - may not be prudent but it is legal. We routinely had to knock off training in MOAs after a call from center that there was traffic, we’d find them and then wait until they were clear before resuming. No hard feelings, I wouldn’t want to burn the gas to go around either. Restricted Areas of course you have to get a clearance through and I’ve generally had good luck getting cleared provided it wasn’t it use.
It’s very likely that your Ak example is unique and their range complex may have had some nuances but it couldn’t be anything more than an arrangement of MOAs and restricted areas. So your range control was doing exactly what they should have been doing for civilian traffic. FWIW, we often couldn’t do much with MOAs as their floors were too high for much of our maneuvers.
I have a call in to Flight Service, I want to verify what their procedures are for recording MTR use reported by military users. I’ve spoke to a number of military buddies and all recounted making the same reports to FSS that I’ve described. If FSS isn’t making that info available to civilian inquiries they’re missing a big opportunity to bolster procedural deconfliction. As I said before, the system works best when everyone participates.
Paddles wrote:I’m a Navy dude up here at NAS Whidbey Island. ...the training is valuable and dudes like me flying gray jets take pride in being professional, adhering to the published restrictions and being good stewards of the airspace we have.
