whee wrote:I enjoy a good HP vs Tq discussion.
In a STOL situation isn't Tq what we really care about? Tq is what is going to get our prop up to desired rpm quickly thus giving us a better holeshot. Doesn't it take a turbine a second to spool up?
It does take most turbines a second to spool from a low idle, and this is usually due to a narrow powerband. This is usually avoided by using a high idle speed that significantly reduces spool up to operating RPM. On gas-coupled turbines, another source of lag is the design of the engine. The gas producer does exactly that: produces hot gases to spin a turbine that is connected to the power user (that turbine is called the "power turbine"). When you demand the power, the gas producer has to produce the gases by injecting more fuel, heating the air, driving its own turbine faster (which is shaft coupled to the compressor), compressing more air than it was, injecting more fuel, etc. This then provides a greater volume of hotter gases for the power turbine to use, increasing the power output of the engine. You can see where a lag could form!
Torque is immensely important in all aspects of the engine, but its an incomplete picture. If you think about saying an engine doesn't have enough torque at low RPM, you're describing the horsepower (talking about torque and rpm put together is effectively the same as just talking about horsepower). A more meaningful discussion would be the shape of the power curve. Riding a 2-stoke dirtbike, you'll experience a very "peaky," or "narrow" powerband. Riding a big cube 4-stroke dirtbike, you'll experience a very "flat" powerband. Even though both may have the same power output, one might be more effective for racing and another might be better for trail riding.
In reality, you could also say that an engine has a flat torque curve, but that gets away from talking about what really matters in an engine, and that's the power output.
I think a flat powerband is very useful in backcountry flying - specifically with a fixed pitch prop. If my static RPM is 2300, I'd like to develop as close to my maximum rated power at that RPM - all the way up to my maximum of 2700 RPM. In reality we're talking about 400 RPM, which in higher revving automotive applications is easy. I'm not familiar enough with aircraft engine cam design, head flow, typical dyno charts, etc. to say if that's common in my O-320. Anyways, due to those extra 400 RPM, I'd probably see more thrust from the propeller at 2700 RPM than 2300 RPM, but if I had a flat powerband I wouldn't be losing thrust output at 2300 RPM due to feeding less than my rated horsepower to the prop. Fixed pitch props being a compromise, I think that's the best we can hope for in that scenario.
With a constant speed prop, I'd argue the minimum pitch stop setting and speed of the prop governor matter more and the powerband could easily afford to be more narrow. That's probably a different discussion though
