http://www.youtube.com/v/WLkW6ktt6V8
a64pilot wrote:So,
Flaps are not used to shorten the take off distance on a Bonanza?
4 souls on board w/luggage. Full fuel. About 4k ft DA tailwind up hill take off headed to Mexico for the Labor Day weekend.
lowflybye wrote:Armchair pass: why not gain airspeed (ground roll) without flaps, drop the first notch at stall speed and pull her off the ground into ground effect. Retract the gear in ground effect to gain airspeed and climb over the obstacles before retracting the flaps.
lowflyin'G3 wrote:I don't think flaps matter as much on those wings but I'd have to agree with A64 that a bit of flap would have to help. Along with gear up IN ground effect and keeping the nose down to allow the airplane to accelerate IN ground effect. Then possibly rolling the flaps down a bit more to balloon up over the obstacles with a little back pressure when you get that far. Not something you want to do alot but it's saved me more than once while spraying off of short strips.
Of course common sense, proper prior planning, maybe even use of the manual for W&B and performance charts would all avoid the sucking up of the seat cushion into said buttocks (or even death) at the departure end.
That Bonanza Man dude that comes around here does as sporty of operations with that type of aircraft I've seen and seems to be good at it. I bet he'll have some insight for us as we armchair this one.
a64pilot wrote: How many cans of gas do you have to have in back to get 120 gls. in a Bonanza? With the flint tanks, I get 120 in the 210, but I always thought the Bonanza didn't carry much.
mtv wrote:As to the gas question, the accident aircraft was an A-36 Bonanza. They carry more gas than a 33 or 35, and have more horsepower.
He flew the airplane off the ground, then horsed it up out of ground effect, and didn't retract the gear. That, combined with everything else, was obviously not good.
These airplanes are sensitive to CG as well, so you'd want to see what the CG was.
