NineThreeKilo wrote:Always be wind aware, even if your panel calculates winds, always be looking for signs on the ground and the sky, be visualizing where you’re going to get a boost and where you’re going to sink.
If you have 25kts of wind at the peaks or clouds close to the peaks, airmet etc, exercise caution
Fuel wise if there is nearby fuel or fuel at destination I plan to land with 1hr fuel, anything under is not wise, anything over is a performance loss, especially if you default to topping long range tanks.
Like MTV said go out and experiment with climb and turns in a controlled environment at different weights, one good one to play with, figure you’ll lose about 1” of MP for every 1,000 MSL
Another good one to play with, calculate your true airspeed on landing & apprch at any high altitude airports you are going to be landing at, shoot a approach back home at that speed, obviously your wing will preform better down low, but still a good visual to experience in practice before actual
You can also go to a nice big runway and practice taking off at simulated DA by changing the MP as mentioned above, pick plot out how long the strip you’d be landing at would be, nice safe way to first experience it
Also aggressive ground leaning for taxi
Also also remember you may need to do a full power static runup to get your mixture right talking off at high elevations, just the same going “full rich” for landing can be problematic up in the thin air
flyingjack wrote:StillLearning +1: I'm located in Denver area, I take Husky and fill it with sand bags and full fuel for a gross weight. Then go out on hot days with DAs of 10K and practice at 3-4K AGL= slow flight & turns, stalls and short spot landings. That performance basically becomes my "worst case performance" default. I am not any kind of instructor and this exercise, which is probably wrong is not intended as actual advise; just what I do.
