bigrenna wrote:hotrod180 wrote:...that everyone will raise so much hell about it, that the whole ADS-B thing will just go away.
I really dont understand what all the fuss is about. I have been taking advantage of ADS-B for the past 150hrs since I finished my wagon project and I find it amazing. Although not a panacea, it is a fantastic tool that has helped situational awareness.
Greg,
One of the issues is that you are talking about a completely different animal than the regulation calls for opinion 2020. You're talking largely about ADS-B in, but the reg only requires ADS-B out.
And, as of yet, the FAA hasn't settled on exactly what "flavor" of "out" will be acceptable. So if you have ADS-B out now, it may or may not meet the yet to be finalized standard in 2020. Hopefully it will, but......bear in mind that to date the FAA has said no transponder will be required, then changed their mind, and a few other changes.
Also, it is becoming apparent that the current ADS-B technology may not be accurate enough to provide "radar-like" traffic separation.....which was specifically the purpose it was developed. Doesn't mean it won't give you valuable "hints" of course....but only with "in" which is not to be required. And we don't know if that'll change as well.
And, it's expensive. I mean no offense to you, but you've out way more money in your airplane than a lot of us could afford. It's expensive....and, I don't have an electrical system. I shouldn't care, you say, because I'm exempt? Read Soy's comment above and read my diatribe about drones in this context in another thread.
One more point: The FAA decided to introduce ADS-B in western Alaska, many years ago. They spec'd out the equipment for a bunch of planes, got the stuff installed and operational, then "discovered" that the Air Force was using that frequency for datalink between F-15s operating in the Stony MOAs. In other words, the FAA didn't check to see if the freq was in use. The AF had to change their equipment to deconflict.
So, these are the folks who are deciding what equipment we should/must install in our aircraft.
And, the drones are coming.
