Backcountry Pilot • I need to vent....
I need to vent....
8 postsPage 1 of 1
I need to vent....
Hi guys, A few friends emailed this to me and I just had to respond. :lol: :lol: #-o [-X
On the "801"
“This is an accident waiting to happen. The motor mount is incorrectly designed with un triangulated bays and bent tubes in tension and compression. The firewall forward weight is at least 450 pounds aluminum block or no aluminum block. No mention is made of beefing up the fuselage to take the vastly increased bending loads during landing and high G turns not to mention the increased bending loads on the wing spars. Zenairs are not over designed to begin with having very thin skins.
"The fuel burn is better then expected though and I am presently confirming the JPI 450 for accuracy. Cruise @ 11,000 msl is producing 5.9 0 -6.3 gallons an hour."
The numbers quoted above shows a lack of understanding about engine engineering in general. The fuel burn quoted at 6 gallons an hour or 37 pounds an hour means the engine is only generating 83 HP giving it the benefit of a BSFC number of .45. In the unlikely event the BSFC is as low as .40 the HP then would be 93 HP at the absolute maximum. Now you have a 450 pound firewall forward weight putting out 93 HP at cruise.
Something is seriously wrong.
"The numbers I am shooting for are one pound of engine weight for each horsepower and a small total engine profile that will fit in most airframes."
What he is saying here is he things he is going to get 350 to 400 HP with a 1.43:1 PSRU ratio. With a 2600 RPM prop that is 3700 engine RPM. No way is that going to happen.
This person is totally clueless.
I am really worried here. Probably one of the most dangerous airplanes I have seen in a very long time.
Paul Lamar”
I don't know who this "person" is or what his qualifications, but..
I am compelled to answer his hatchet job on every topic.
My project is a one of a kind. I had no group, forum or any other source to go to during the design, and test flying of my experimental aircraft, so all the calculations, fabrications and installations are a one off and done to the best of my ability using past life experiences from fabricating stuff on race boats, cars and god only knows whatever I have modified in earlier years.
I built my plane, 3000 + hours of MY time. I didn't buy a half built one, or a completed one to use a test bed for my powerplant. I have been flying for almost 30 years and owned several other planes.
My experimental plane has been flying for 5 years and 300 hours. Been flown in air from 97f to -37f. Has over 500 landing, been flown from JAC, 6430 msl to 18,000 feet, full throttle, !! over a couple of dozen times to test it for strength. Been flown in all other power settings to comfirm and quantify data. Tested to +3.5g's to - 2.5 g's. Flown to OSH and back... not trucked there as others seem to do to display their creations.
My responses..
1- When is this " accident" going to happen ??
2- The mount is designed by me using triangulation, just go to my web site and look at the pics.
3- There are NO bent tubes in my mount. there are intersecting angles but that happens on ALL mounts. At those intersections the area is beefed up internally. Just because you can't see it doesn't mean crap.
4- I know EXACTLY what it weighs. I don't guess like he seems to. And it is less then his "estimation"
5- Of course I beefed up the airframe as I built it. Just because I didn't state that on my website should not give him a pass at a free shot.
6- Zenith Aircraft seem to be an "issue" to him. Mine has twice the "suggested" HP and still has not broken in half.
7- The plane has so much power that at cruise I can throttle back to ALOT.. A 801 has alot of aerodynamic drag. I can run 90@ 6.4 GPH or 110@ 17 GPH. The plane hits a brick wall so why burn three times the fuel to go a little faster. If I wanted to go fast I would have built another type plane. You would think a guy like him could draw a simple conclusion.
8- I have probably built, raced and tested more engines then he can dream about.
9- BSFC of .45 ??? Jeez. I would be embarrased to tune a motor that rich.
10- Nothing is " seriously wrong"............. I am seriously throttled back.
11- The motor is capable of 600 + Hp in different trim. ie, different redrive ratio, different intake design, etc. The motor will not gain any more weight by changing componants, so 350-400 Hp is a no brainer.. On MY plane I purposely stayed with 1.43-1 because it for sure doen not need any more power.
12- Where did he get the 3700 RPM # from ? I turn the motor alot higher then that on take off. Yeah, the prop is kinda noisy but nothing worse then what noise a seaplane makes with a large diameter prop.
13- """ Totally Clueless""" Ya wanna bet..
And in closing all I can add is
" I am really worried here. Probably one of the most dangerous airplanes I have seen in a very long time. "
Geez... Where was he 5 years and 300 hours ago ??????.
Ben Haas.
Now..... I fee alot better <GGGGGG>
Stol offline
Re: I need to vent....
Mr. Haas, I have seen the photos of your 801 on your website, and it looks very interesting and well-executed to my amateur non-engineer's eye. Congratulations on a great achievement! I believe Paul Lamar is one of the known "experts" in experimental airplane engines. If i am correct in remembering, he was once upon a time one of the engine builders on the Chaparral series of race cars. This of course does not mean he is right about your installation, or any more educated than you are on your airplane. The fact that you have done some amount of testing on your installation gives you a fair amount of credibility. I believe he does know a lot about engines, but again you may have already considered all the things he thought you had not.
I do hope you beefed up the Zenair structure as appropriate for this installation. Mr. Lamar may be wrong about something else but I must agree that his comment about Zenairs not being overbuilt rings true. A friend of mine was 75% complete on a Zenair 601 and had to put it in a storage container until they figured out why they were coming apart in mid-air. Heintz is a good designer I believe, but there are compromises he makes that I would not. But he's a trained engineer... but I'm not... but he is an established designer... but I've had enough model airplanes come apart to have a "feel" for airplane stuff, etc. etc. Bottom line if I built a 701 or 801 I would be adding many stiffeners and a few more pounds of metal in a couple of places.
Congratulations again on a fantastic achievement. I hope that the V8 conversion on your airplane was worth all the effort you took to do it.
A 601 and an 801 are two different cats all together.
And on the coming apart issue the Feds said it was flutter, an independent lab has reported properly built there is not a flutter issue.
Many suspect loose rudder cables may let flutter occure, the lab didnt test them loose
The point of this thread is :?: :?: :?:
mr scout offline
mr scout wrote: The point of this thread is :?: :?: :?:
I guess he just needed to vent...
Must have been an abused child ................
I am building an 801 with a Chevy V6 ..... I engineered and welded up a mount .. . . turns out to be much like Ben's --- nice mount Ben .
Evidently someone does not get around airplanes much ... or have very little knowledge of 801's.
So ...... what are you flying ???
Yeah ......... I beefed my firewall mounts back thru the fuselage, mine has dual stick and a console ....... oh yeh, guess that ain't no big deal, after all
we are "Experimental"
Bert a
Beach801 offline
A V-6, [-X and,,,,,,,,,,,,, dual sticks, [-X and,,,,,,,,,,, a console. [-X .. my son the heck with Paul Lamar.. You sir are going straight to hell without supper.. [-o< [-o< #-o :D
Beach801 wrote:Must have been an abused child ................
Bert a
Stol offline
About 4 years ago, when I was flying my EA-81 powered Rans S-7, I made a quick stop in Jackson Hole. I met Mr. Haas and got a quick look at his plane. It showed great attentiuon to detail and overall great workmanship. He was kind enough to advise me that Cheney was due to arrive, or at least it appeared that way by various signs the locals recognized, and I hauled outa there before they shut the airspace down.
No fair on his site photos however, ANYTHING would look good with the Grand as a background!
Tom Simko
Ha ha haaaa
These "arm chair" pilots ....... that is okay ...... one has to dream .
banter is good.
Ben and I will fly .... others can only dream .
Mine was a dream once ...... but I did not crit- those that already fulfilled their dream.
Hey , model airplane flying is fun too.... might try that.
Beach801 offline
8 postsPage 1 of 1
Users browsing this forum: No registered users and 29 guests
