Backcountry Pilot • Idaho Airports Ipad App
9 postsPage 1 of 1
Looks like it might be cool but I don't have a Ipad so don't know. Wish it was compatible with the Iphone.
Re: Idaho Airports Ipad App
I've downloaded it and played with it a little - its a good resource - has the same daigrams as published in Hanselmans Fly Idaho book. I am not sure if it will somehow allow pilots to post PIREPS or other tips, which would be cool (ala shortfield.com).
Any chance of Shortfield making its way to a purpose built app? That would be cool.
emflys offline
Did you try the density altitude calculator?
It has no such "calculator" functionality that I can find - it just has some static text/charts that you can use - much like would be in a POH. It also has tips, etc.
Some screen shots:
Maps:
Text/Chart content:
emflys offline
Not sure when the new version came out but it says it added a density altitude calculator.
Thanks for the screen shots.
The current version has a density alt calculator where you enter pressure alt and temp, either C or F, and it gives the DA. It has some Mountain Flying Tips and Survival notes also. It does replicate the directory that the State charges $10 in the printed form.
On top of that, its free to the user - provided by the State of Idaho.
Resky offline
I like this app it has alot of info needed to fly Idaho. Wish it would rotate and pinch and squeeze/expand.
My iPad is best mounted horizontal and it seems that this app is only working horizontal.
Glidergeek offline
Aircraft: 1968 P206C
DG 400
It has a couple quirks that hopefully they'll get sorted out. I needled some friends at Montana Aeronautics about them now being behind Idaho. They said one is in the works and will be better than the Idaho version.
Bonanza Man offline
Nice find! Thanks!
9 postsPage 1 of 1
