375handh wrote:I thought I was pretty good with Foreflight. First, what a great project and my sincere thanks.
Possible to give me a short tutorial on uploading your files into Foreflight? Thanks.
Sure, you'll need to first get the file to your device. I'm only familiar with the iPhone/iPad process, so Android may be different.
Step 1: Use some sort of cloud service to share the file to your device or download the file directly to your phone/tablet.
Step 2: Long press the zip file from your file browser and select "share"
Step 3: Share it directly to the Foreflight app.
Step 4: You will find the new layers at the bottom of the layer dropdown from the map screen
If you want to remove the content, navigate to settings>custom content, select the content pack and select delete.
I hope that helps.
Also one quick clarification: the strips file is meant to locate strips which do NOT already show up on Foreflight maps. IE: hoodoo meadows was deleted from the file because it now shows up on Foreflight.
