OK,
So I know what the minimums equipment requirements for an aircraft to be IFR certified per the FAA but I am more interested in the minimum equipment you guys are running IFR with. Here is why I ask. I am doing a panel upgrade and want to be reasonable/ smart with the panel. I have a 185 with a Stec autopilot. I am puting in a G3 touch with a new gnx 375 for gps and adsb. I have a garmin sl 30 for nav/com and will be adding a remote garmin GTR 20 com for the primary. I also have a garmin 796 that will be panel mounted as well. So I will have 2 IFR certified Navigation systems and 2 comms systems. I will have 2 gps non certified systems for situational awareness. The question I really pose is would you feel comfortable with this setup or would you want a second navigation source either GPS or ILS/VOR? I have a KX-155 but I really want to get away from it all together. Also I am spending enough on the upgrade that I really do not have enough for a second Certified GPS. I believe the GPS/ILS single systems are enough for the type of IFR flying I want to do. Specifically, IFR on top, healthy personal minimums kind of stuff to extend my flying capabilities, not any kind of wild flying into known ICING/Heavy IMC kinda stuff.
Hope this makes sense.
Thanks,
Gypsy
