In a Pickle
Sat May 28, 2011 12:56 pm
Guy and Gals,
I'm in Dothan Alabama on Memorial day weekend. It's Saturday and I tore up my tail wheel Taxing off the runway with a flat. Does anyone have or know where can get a tire and tube for a Monday departure. If so, my Cell number is 410-935-5841. I'm in a pinch and will drive to Moultre if I could contact someone.
Thanks in advance,
Tom
TomKatz offline
244
Tom Katzenberger
Tom - Why not bolt on a 2x4 and just skid your way home??
1749
patrol guy wrote:Tom - Why not bolt on a 2x4 and just skid your way home??
That might work for a Cessna but on a Maule?
Speaking of Cessnas I PM'd you three numbers for 170 owners down that way. Maybe one of them has a spare or can shoo their mechanic out of their Holiday BBQ long enough to get you something.
R
1319
- Location: Keweenaw Peninsula, Michigan and Carson Valley, Nevada
Not that I'd ever admit it myself, but doesn't Home Depot have something "close" to fit?
4557
- Aircraft: Old Clunker
Thanks Guys I will check Home Depot, Tractor Supply and Harbor freight tomorrow. Any additional Ideas are welcome. I will try to call the 170 guys tomorrow as well.
TomKatz offline
244
Tom Katzenberger
Harbor Freight should be your best bet - - usually a good selection of import FAA approved wheels. I'd pick up some washers in case you need them for spacers. Be sure to measure your fork width.
bumper offline
665
bumper
Minden, NV
Husky A1-B
Just don't go to bragging - on line - about any reasonable solution.
Trimtab offline
170
Trimtab
It can be true, even if it didn't happen - Ken Keasey - mostly*
Man invented language so he could hide the truth from others - Tallyrand - sort of
bumper wrote:Harbor Freight should be your best bet - - usually a good selection of import FAA approved wheels.
Yup, those "special" Chinese FAA/PMA wheels. But they work!
4557
Guys,
The tire is too tore up to get the sixe off the side wall. It is a stock Maule tail wheel. Is this wheel the same on all Maule varations and does anyone have the numbers on the sidewall?
Thanks again fore everone help in this matter!
TomKatz offline
244
Tom Katzenberger
Tom the 8" Maule tailwheel I have has a McCreary 2.80/2.50-4 The hub diameter measures 4 5/8" hope this helps.
Foxflyer offline
102
There is a fine line between bravery and stupidity
Lowes has FAA approved Lawn Mower wheels
AvidFlyer offline
1351
