Before:
During
After:
AK454 wrote:I did the doors with the same material. I pulled them off the plane to make it easier for removal and installation of the panels. I used the old panel for tracing the template onto the Kydex.Once you have it rough cut, it is just a matter of trimming and fitting till you like the fit and finish. We did use a heat gun to shape on area to follow the contours of the door. Attention to detail and a lot of patience is required for this part. I will try to get a picture of the door today or tomorrow to show the finished product.
7GC wrote:I did a very similar upgrade with Kydex a couple years ago on my 180. I also used rubber channel on the edge of the Kydex and most of it was friction fit, with a few screws where needed. I had a local shop mix up a few rattle cans of grey paint which I used for the interior metal pieces and the doors and exposed interior structural areas. After 2 years, I'm very happy with how it all turned out. I finished off with Selkirk for the flap tunnel. Now I'm going to rehab the seats.
