iPad Cooling Mount
Although designed for kneeboard users (and only full size iPads it looks like) I could see this also working for those who Ram Mount X-grip the iPad in a location that the sun beats directly on it. Be nice for my 185 passenger if they'd come out with a Mini-iPad version so the vent airflow could go to them instead of the X-grip'd Mini.
https://x-naut.com
Barnstormer offline
2700
- Aircraft: C185
On the features (scroll down) it actually does list it as working for the iPad mini, although that's sort of odd unless there's two sizes:
Works With Most iPads™
Compatible with: iPad™ Air Versions 1 | 2 iPad™, iPad™ Pro 9.7" and iPad mini™ Versions 1 | 2 | 3 | 4
And Ram mounts:
Versatile Mounting
Compatible with RAM™ and MYGOFLIGHT™ mounts.
Good idea for sure. I'm not a fan of the bulkiness, but I do wish my ipad would stay cooler.
1532
Thu Jul 28, 2016 10:42 am
Peltier Cooling Devices anyone?
I have always wondered about taking a thin metal plate that would fit snugly on the back of an iPad, with a series of Peltier cooling devices attached and then a second thin metal plate on top of that array of plates with some outward facing shallow heat sink fins. These peltiers are cheap, run off of 12 volts and can even be solar powered if that's important for you. Ham radio guys and computer overclocking fans use them See Video below.
Peltier Cooling Device:
More Info and Where to buy: http://www.allelectronics.com/make-a-store/item/pjt-13/thermoelectric-peltier-device/1.htmlhttp://www.heatsink-guide.com/peltier.htmVideo: Disclaimer: I have no commercial interest or connection with any of the above
Denali offline
809
Barnstormer wrote:Although designed for kneeboard users (and only full size iPads it looks like) I could see this also working for those who Ram Mount X-grip the iPad in a location that the sun beats directly on it. Be nice for my 185 passenger if they'd come out with a Mini-iPad version so the vent airflow could go to them instead of the X-grip'd Mini.
https://x-naut.com
M6RV6 offline
2313
- FindMeSpot URL: http://share.findmespot.com/shared/face ... sWKXuhKlg2
Yea can't believe I missed that. In too much of a hurry to get on with phone conversations about next year's Texas STOL Roundup.
Barnstormer offline
2700
- Aircraft: C185
