It's fall again! Here in the Wellton / Mohawk valley of Yuma county that brings the start of the produce growing season!
Gila River Flying Service is now hiring seasonal ground crew help, and current openings are for fixed and rotor wing aircraft loaders and tanker drivers. We are a growing aerial application service operating Turbine Thrush and B206 helicopters.
Job description and duties
Aircraft loaders and tanker drivers primary duties are mixing and loading chemicals, as well as fueling of aircraft. Additional duties include pre and post flight care for mix and load equipment, and assisting flaggers, pilots, and other loaders or tanker drivers in completing their respective mission.
Loading and fueling aircraft can be compared to working on the pit crew of a race car, and in the rotor wing division you add the diversity of running the chase vehicle to the mix as well.
Job requirements
The ideal candidate will be a self motivated team player with a passion for aviation, agriculture, and challenge. Candidate must be a problem solver, and be able to function smoothly in a high stress environment.
CDL, EPA card, previous chemical handling, aircraft handling, or agricultural experience are all pluses but not required. We can teach everything but a broken attitude here.
These positions are for ground help only, and are not intended to infer a future in a flying position, and are best suited for an individual moving forward on a career path in farming, agronomy, aerial application, or an aviation career outside of the Airline / Jetset industry. Having said that GRFS is a young and growing flying service and the only limit on a candidates growth within the company or industry are self-imposed.
Job pro's
Feeding America! If you ate a salad anytime from fall through spring, we probably took care of it!
Working in and around cool aircraft !
Working outdoors !
Job con's (realities)
Scheduling. This niche within the industry is primarily a '911 service' A typical 'day' starts at 4pm and ends when the works completed. There may be no spraying that day, which would mean an early day, or there may be spraying in to over time.
Occupational hazards. Fuel, chemical, equipment, and constantly running aircraft are all part of this job. If the thought of hot exhaust, pesticides, HOT LOADING / FUELING of aircraft make you squeamish, this is probably not a position for you to consider.
Stressful working environment. By nature of the primary task at hand, the working environment, materials, and scheduling, these positions can be stressful. Applicants must be able to perform under pressure.
Candidates can respond with a PM here for more information.
For those interested, here are a few examples of our fleet and working environment. Thankyou Zzz for the opportunity to post this job opening here.
Take care, Rob
