Backcountry Pilot • Project: John's 1955 'Super-70'
48 postsPage 1 of 31, 2, 3
After owning several planes of completely different styles, I found myself most fond of the 170 I had several years ago. The 170 has fantastic visibility due to the high wings and low panel. It is easy to load, easy to fly, easy to land and will haul as much as you can fit into it...but it is sort of slow and underpowered with the stock 145hp engine.
The perfect plane would be the 170 with more power. And so the story begins...
A friend of mine since childhood has a wonderful habit of buying planes and old cars and he enjoys rebuilding them. He is a masterful technician who is as comfortable with a rivet gun and sheet metal break as most of us are with a TV remote. His impeccable work quality is recognized by the local FSDO and he has successfully adapted many modern features into old planes by way of field approvals.
The basic starting aircraft
We begin with an undamaged 1955 Cessna 170B. The 'B' model was selected because of the best wing design of the three versions. It has the largest ailerons and big Fowler style flaps that are adjusted quickly and easily with a convenient single lever between the seats. The 'B' also re-routes control cables to the subfloor, making a clean useful load area. And because it was certified under Civil Air Regulations (CAR) part 3, it is much easier to get modifications done and approved (more on the changes to the cabin, wings below).
Fuselage:
The goal is to make this a strong, light weight 4-place plane that can carry over 1000 pounds of fuel, cargo and passengers with ease and comfort. With the advent of active noise canceling headsets, the need for heavy sound insulation is eliminated. The entire interior of this plane was stripped, zinc chromated and painted. No interior trim panels will be used. Skylites were installed as done in the Cessna 120 and 140 models. A baggage door from a Cessna 172 was installed along with the Extended Baggage STC by Selkirk. New control cables, bearings and pulleys were installed throughout. A BAS retractable tail pull handle will make it easy to move around. Because the plane will be operated on skis and the possibility of floats, a float kit from a Cessna 180 was used. This kit uses larger reinforcing doublers spreading any stress over a larger area. A V-Brace by F.Atlee Dodge will strengthen the forward cabin door frame areas. New fuel lines were bent and installed with new AN fittings. Cowl steps and grab handles on each side will make it easy to get up to the fuel tanks or windshield without a ladder. All the windows were replaced with new. The steel side window frames are replaced with aluminum frames from a C180 that saved 12 pounds. The hand pump and hydraulic lines for the skis will be installed between the seats. The old aluminum firewall was replaced with a new stainless steel one. Heavy duty rudder pedals from a C180 replace the originals.
Engine:
The stock engine is a 6-cyl, Continental 300 cubic inch with 145 HP. There are several STC's that provide for the upgrade of the engine to the 4-cyl Lycoming -360 series that makes between 180 and 210HP. We chose Del-Aire STC. The weight difference between the two engines is about the same and the extra power is a real bonus!
We took a Lycoming O-360-A2D with only 65 TTSN, and replaced the 'shower of spark' mags with new Bendix dual impulse coupling mags. This allows for hand starts even with zero battery voltage. The starter motor and alternator was changed to B&C and an MT compact propeller governor installed to save weight. A spin on oil filter adapter was also added along with the Bracket air filter. The intake and exhaust ports were polished to aid in airflow. The exhaust system uses header pipes with no restrictions to the heat muff collector and large diameter outlet.
The engine was dressed up by adding a bit of 'bling'. The paint used is Lycoming Grey with a bit of hardener added for shine. The baffles were painted black before installation. Push rod tubes, rocker covers and intake risers were chrome plated. Copper lines and brass fittings all received a good polish before installation.
Propeller:
A 79" MT Composite 3-blade constant speed propeller from Flight Resource was selected to harness the engine HP and turn it into thrust. The MT prop is lighter than the fixed pitch prop and allows the owner to use the full power of the engine at takeoff and set for low rpm for economy cruise. The composite blades tame and absorb the notoriously strong firing pulses of the -360 series engine and the prop has stainless steel leading edges for unlimited life and durability. It provides the highest static thrust of any prop available for this engine. It was installed via a field approval deviation to the 2-blade MT prop STC sold by my company http://www.Flight-Resource.com.
Seats:
The seats were stripped of the old, heavy springs and wool padding and replaced with Ceconite bases covered with modern aircraft padding and fabrics by Sport Aircraft Seats of Wasilla AK http://www.sportaircraftseats.com. New seat rails and BAS inertial reel seat belt systems were installed.
Landing Gear, Wheels and Brakes:
The stock gear Cessna installed on the 1955 C170B is nearly perfect. It is a bit stiffer than earlier years and has a nice looking shape. A P-Ponk gear box reinforcement kit was installed as well. The plane will be equipped with Federal AWB Hydraulic Wheel Skis, so the stub axles and brackets were fitted at this time. New Cleveland wheels with dual cylinder brakes were installed that allow for the use of tires up to 32" to be stopped with ease. Of course, all brake lines are new and the master brake cylinders were rebuilt as well. It will be fitted with 8.00 tires to begin with. Spats from a 185 spray plane will keep the mud off the wing bottoms.
1-year update
So here we are now about 1 year into the project. The fuselage is at the avionics shop getting all new panel and wiring. The pics below will chronicle the work to date. I will continue to provide updates. We might have it flying this winter.
Baggage door and interior:
Interior now painted with Military Surplus Interior Grey Enamel. We trimmed the extended baggage floor and test fit. Carpet is temporary padding. Rudder Pedals and Firewall installed.
Exterior Paint:
We shot the entire exterior with Imron. Color will be added on top.
Color done on fuselage:
Engine is now mounted using C180 solid (seaplane) bushings. Windshield is trimmed and fitted and V-brace installed. Notice the chrome plated grab handles on the cowling.
I got a fin & tail!! The doors and cowling are temp fitted to allow marking for paint lines.
Now the fuselage gets moved to the Avionics shop. Meanwhile, the wings and control parts are opened up, stripped, cleaned, zinc chromated and painted:
New fuel lines are prepared. New hydraulic lines and the fittings for the hydraulic skis are installed.
Now the panel:
A new panel was cut and only the basic instruments required by the type certificate will be reinstalled. The engine STC adds the need for manifold pressure and fuel pressure gauges. A Garmin 496 in a AirGizmoz mount provides GPS navigation. A Electronic Flight Instrument System from Grand Rapids Technologies provides the means to monitor every aspect of the engine operation, fuel burn and power being produced. The EFIS display also takes GPS data from the Garmin along with pitot and static air data and feeds from a remote magnetometer and built in AHRS to provides a complete full function backup guidance and flight direction system. It even includes AOA functionality.
Wiring: All original wiring was removed and will be replaced with modern Teflon coated wires. Fuses are replaced Klixon breaker-switches. Whelen tip strobes will be installed to help to be seen. Interior cabin lighting will be combination of dim-able self-lit, post lamps and a light strip under an eyebrow we will fabricate and mount to the top of the panel.
Radios: A new 720 channel digital radio and King Mode C transponder will be used. A PS Engineering 4-place stereo intercom with multiple aux (music) inputs makes communication and entertainment in the cabin perfect. The ELT will be changed to the new 460Mhz version with interface to the GPS. Tom Bauer, owner of Top Flight Avionics in Cumberland WI gets huge kudos for his nice work.
This is what it looks like so far:
As of today (December 12, 2012) the wiring is about done and we will be relocating the plane back to the other shop were it will be mated with it's wings. Lots of work yet to do to connect all controls, set angles and tensions, connect engine to panel.... Still hoping to fly it this winter. I will keep posting updates and pics as we move forward.
john54724 offline
John Nielsen
Co-Owner
Re: John's 1955 'Super-70' Project
robw56...look away....LOOK AWAY!
She's beautiful, John.
Really, really nice.
daedaluscan online
Looks great!!! I just started my own project on my 53' 170B, although its not going to be quite as nice as yours. I have a question, which window frames are you talking about that saved 12 lbs? I just drilled out the rear windows and the frames holding those in are very lightweight aluminum. Are you talking about the frames holding the door windows in? I haven't removed those yet. Do you really think you'll be able to get down to 1200lbs empty weight? That would be REALLY light if you make it happen. I'm shooting for 1300lbs on bushwheels with my 170.
The all new 2014 Cessna 170! Looks really cool!
Scolopax offline
The widow frames in the doors of the 170 are heavy steel. The 180/185 used alum. The size is the same.
john54724 offline
John Nielsen
Co-Owner
Please sell me this beauty! [-o<
You can always build another one, right!? :D
MAU MAU offline
Maule MXT-7-180A
Re: Project: John's 1955 'Super-70'
When I die I want to come back with your skills, or Bigrenna's...
Floatsnskis offline
Just wow! That's a beauty, incredible work! Is the base color off-white or white? Still contemplating my paint job and thinking about an off-white base for the scheme but can't decide how it'd look.
Looking forward to seeing pics when it's done.
Vick offline
Solum Volamus
Vic
Don't waste your money on paint, it'll just get scratched up #-o
Happy Holidays
Gary
shortfielder offline
+1 on the me too factor. Wow.
Mister701 offline
Aircraft: Rans S7LS
Looks great. I certainly know how much work is involved. Kudos! (Rob you are most def in trouble. Someone hide his wallet)
Im interested in the window surrounds. Not sure if I understand what part you are talking about that saved you 12 lbs?? When I restored my 1952 C170B, I pulled the window frames, powdercoated them, and reinstalled sans the headliner frames. These were all super light and weighed ounces, not pounds.
Keep the pics coming! Cant wait to see this in person!
www.avthreads.com
Wow - dedication to the cause!! =D>
Any updates?
It has been a while since I updated status of my project. The doors and baggage door has now been painted with the blue & yellow trim colors. The wings have had the tanks installed, tips installed and are in a trailer ready to install to the plane. Today the cowling gets the trim colors added and should be ready to install next week. The firewall forward work is officially complete...
We moved the plane 50 miles south to my local hanger, just 2 miles down the road, so I can get to it nearly every day to dabble a bit on interior trim. I began test fitting the doors and will add the seals today. Then the door windows are next.
The wing control surfaces need to be painted white after the cowl is done, then balanced. When all those parts are back home, we will mount the wings.
The panel and wiring/plumbing to the instruments is complete and tested...they all seem to work!! So did the intercom! Kudos to Tom for his masterful wiring talents.
I am also covering the interior with 1/4" closed cell foam..that does take time, but I won't let it delay first flight. Goal is to get things done to make first flight end of May or early June...we will see....it has been 2 years in process.
More to come...
john54724 offline
John Nielsen
Co-Owner
Looks awesome! Only think I would do is use a razor knife to cut the ends off the zip ties flush with the body. Those things are ginsu knifes that have sliced and diced me pretty good before.
akavidflyer offline
Very cool!
www.avthreads.com
Looks great! Is that your copilot headset jacks next to the glove box? My new panel covers the old holes and I need to relocate the jacks. I didn't think there was room next to the glove box like that but maybe I'll have to take a second look. That looks like a great place for them.
Hey John, missed you at the Airmen's show.
WOW! I think this is my dream plane.
daedaluscan online
