Johnson Creek Smoke Report
Planning on leaving tomorrow (7/22) for Johnson Creek. It seems the web cam is down and was looking for a smoke report.
Jeff
propeller26 offline
174
- Aircraft: Cessna 185 Skywagon
Jeff, check the cams at Big Creek and Yellow Pine. There is quite a bit
of smoke but you could probably be ok at Chamberlain for a while. I may
have a report later today from a friend heading that way this morning.
How is that new panel working our?
Larry
Pukingdawg offline
31
- Aircraft:
RV-4
Unfortunately, I have only flown it once since the refurb, however, it is amazing!
I will be looking for an update and checking the webcam!
propeller26 offline
174
Sun Jul 23, 2017 12:45 pm
Have a look here:
https://idahoaviation.com/webcams.php list of Idaho aviation webcams. The yellow pine NW cam is up and working.
TD
TomD offline
1113
- Aircraft: Maule M5-235C
Flew over johnson creek this morning, and landed @ big creek. It was a bit hazy early when the sun was at a low angle but not bad. Should not be a problem. Watch out for the TFR between johnson creek and big creek.
scottf offline
650
- FindMeSpot URL: http://share.findmespot.com/shared/face ... cbQCpIqefS
Rats. That puts the kabash on flying to JC for a while.
Mountain Doctor offline
641
- Aircraft: Maule MXT-7 180A
