Super-Maule wrote:Waterboy wrote:You might want to take a look at the legend on a sectional chart. This is printed on it.
Hello Waterboy,
I would agree that landings are prohibited within the areas depicted by solid blue lines and dots on the sectional chart is correct. The legend on the sectional chart is however not quoting specific Federal Law. The sectional chart legend verbiage would have you believe that landing on
any Forest Service designated property is prohibited. This is simply not true in accordance with 36 United States Code 261.13. This law supersedes all state and local laws. The specific law was brought to my attention by a Federal Judge in a case recently. The defendant won his case of landing on Forest Service property within Washington State.
There are thousands, if not millions of acres of Forest Service designated property that is
not depicted as "wilderness", "wildlife areas" etc. This is Our land, American land that can be utilized with respect and common sense. I plan to carry a copies of this law in my airplane. If I am ever questioned by FS personnel on FS designated property, I will simply give them a copy. CFR 261.15 (use of vehicles off road) does state that you can't operate as to become a hazard, so be careful.
Merry Christmas,
James
Clear Creek, Idaho
& PS: Zane, thanks for the new spell check and all your efforts on BCP
James,
I think your conclusion is accurate, but for a little different reason. The chart statement reads "landings are prohibited on lands managed.......without specific authorization by the respective agency."
So, if an agency specifically permits landings on its managed lands, this chart legend is irrelevant THERE. An example is in Alaska, where aircraft landings are specifically permitted in most if not all parks, refuges and forests. That chart legend still appears on the Alaska charts.
The question then remains whether the Forest Service actually permits aircraft landings on National Forest lands, and your citation of the USC suggests that they do, UNLESS specifically prohibited.
So....here comes the tough one: A particular national forest MAY have specific regulations that actually prohibit aircraft landings. Nothing in that USC cite that you posted prohibits a specific forest from being more restrictive.
The question then is: Are there any specific restrictions on aircraft landings in national forests, other than big W wilderness areas?
I would think that the FS legal department would have to answer that.
Point is, having that citation in your pocket won't do much for you in an enforcement case IF there are local restrictions.
