I recently arrived from Alaska with 31" Bushwheels on my cub. In Canada all the airports along my route have grass landing options that are commonly used. On short final into Bellingham, I requested permission to touch down on a "patch of grass". Since the airport has had recent work, re-grading, and hydroseeding it was "not advisable" and "at the pilot's discretion" (I think a controller would always indicate "at the pilot's discretion"). I landed on a short, recently seeded spot (unofficially recommended by the helpful controller) between RW 16 and parallel Alpha Taxiway, between Delta and Echo taxiways. There were signs and lights to avoid but they were confined to the perimeter, as is often the case, so be careful turning onto a runway or a taxiway.
Anyone have experiences requesting a non-standard landing on the grass or gravel at tower controlled fields?
Can anyone offer information about airports in Washington's Puget Sound area with paved runways with landable grassy areas that are typically or seldom if ever used but are the preferred spot (tower controlled or not). Please share your local knowledge for future reference and also to help make this safer when going into an unfamiliar field. Provide enough detail (using taxiway names and runway numbers) to identify the spot using Google Earth, or airport diagrams.
Thanks
That is the only controlled place I've been/asked since installing my Aistreaks. Uncontrolled I just do it, and have gotten nicely bitched at once, threatened with Homeland Security action once (cut the corner of a secure passenger loading zone), gotten a few funny looks (like it was accidential), and no problem the other 95% of the time. I would expect almost no controlled strips here will allow it, due to never being asked, it catches them by surprise, and they go to the fall back answer, NO.
