Tue Oct 27, 2009 11:59 am
I have a cessna 180 which started out on 8.00 X 6 tires. Traded out the 8's for ABW 8.5 X 10s on their 10" wheels which were nice for going to the strips in Utah. Went to Alaska and wished I had just gone with the 29 X 11 X 10s. the 8.5 X 10s gave adequate cushioning for rough strips, but didn't have enough flotation for beach landings without worry, even trying to stick with the dark wet sand. The 29s would have been nicer in the rough stuff too, of course. In going with the 8.5 X 10s instead of the 29s, I was trying to save weight. The figures I got from ABW at the time led me to believe that the tires weight differences were significant. However, only 10# total difference to mount the 29's. I will be buying the brushed 29s next trip to Joseph before next spring travel back up to AK.
On the flip side, I just put 8.5X6s and my Scott tailwheel back on. with a weight savings of almost 50#. The bigger tires are awesome when flying off airport and on the sandy, rough strips in Utah. In the Idaho backcountry, however, the 8s or 8.50s are fine and the weight savings mattered to ME as I started going into the shorter strips and pushing my limits. My late model skywagon with the standard O470 can be a bit of a pig compared to earlier models and I have been trying to trim weight as much as possible. Also, I am putting in about 3,500 miles this week X-C and that 7-10 mph diff makes a decent difference.
Bottom line: The next ribbed tire size up for you from the 8.50X6 is the 8.50X10 and then the 29X11X10 on ABW 10"wheels. ABW and goodyear also make some nice balloon type tires for the 6" wheels. I took some pics of all the sizes mounted up and stacked together - will try to post soon. Seems the 8.5X6 is 21" diameter, the 8.5X10 is 25" diameter and the 29 is 29.
Weights to the best of my recollection:
3 bolt Cleveland wheel w/disc - ~7#
6 bolt - 8.5#
ABW 10"wheel w/disc - 16.5#
8X6 tire 6ply ~11#
8.5X6 tire 15-16#
8.5X10 tire ~23#
29X11X10 tire ~28#
