Leading Edge Tape
What’s the best stuff to use and how removeable is it?
TxAgfisher offline
294
- Aircraft: C180 and Super Cub
Thu Sep 20, 2018 11:27 am
Mylar tape, its formable and very resistant to weather and rocks/dirt. Once its on there it will stay, clean the paint/surface first with iso or some other cleaner. It comes off in one piece, if the paint under it has loose/flaking pieces, they will definitely come off on the tape, but well adhered paint shouldn't pull up. Use it on antenna's and light lenses on biz jets.
Newbizor offline
113
Thu Sep 20, 2018 12:04 pm
Which lading edge-- prop, wing, or horizontal?
I've seen some sort of tape used on all of them.
10534
Looking to do lift struts, gear legs and horizontal.
TxAgfisher offline
294
3M 8672 is 8mil
8671 is 14mil
The correct way to apply it is pretty involved...
https://www.aircraftspruce.com/catalog/pdf/PPTApp%20Instrdec%202008.pdfThere used to be kits for props made from one of the 3M tapes. I remember the trick to getting them to stay on was to follow the instructions (duh) and wait the 48-72 hours (I forget what it was) before running the engine to let the adhesive cure.
PilotMikeTx offline
69
Mon Sep 24, 2018 10:53 pm
That stuff posted last is overkill for jets. What your looking for is commonly used on race cars etc. use it as you are looking to do in my Husky. Use spray bottle with a little dish soap to wet surface to make installation easy. Sold at Jegs auto online.
https://www.jegs.com/i/JEGS/555/75021/10002/-1
RB442 offline
1
- Aircraft: Aviat A1C
