I have heard several techniques for this.
Some had said to always depart full rich and then lean just after TO. Others like to lean durring the run-up.
This next part comes from Sparky's site and thought it was interesting.
I hate to sit at the end of a runway and run up the engine to adjust the mixture. In addition to the possibility of picking up rocks and debris that may damage the propeller, adequate cooling is not available to the engine and its accessories. If the runway is too short to comfortably allow adjusting the mixture during the takeoff roll, use full power to adjust the mixture. Adjusting the mixture at the magneto check rpm isn’t advisable. Even without a power enrichener valve (maybe the engine is fuel injected, so you don’t have it), the fuel flow changes at higher power settings making it inadvisable to adjust the mixture with partial power.
Since your runway is long enough, I prefer to start the takeoff roll and begin leaning the mixture immediately. At the first sign of engine roughness, increase the mixture (push it in) until the engine runs smoothly. Warning: Sometimes when the mixture is pulled out the engine is going to stop. Don’t panic and shove the mixture control back in to the starting point or you’ve defeated the purpose of the adjustment. Make a small, smooth increase by pushing the mixture control back toward rich until the engine runs smoothly. This will give maximum power for the takeoff. Fine tuning of the mixture can be accomplished after climbing 400- to 1,000-feet AGL.
"I assume the sequence is: full power, gauges in the green, adjust mixture, and airspeed alive. Is this the correct sequence? Also, does adjusting the mixture during the takeoff roll affect reaching 70% of your takeoff speed by the halfway point?"
That is the correct sequence for the takeoff. The rule of thumb remains the same, obtain 70 percent of the liftoff speed prior to or at the halfway point of the runway.
This is the part that I found interesting: Adjusting the mixture while rolling just allows you to obtain that speed sooner.
And don’t forget to adjust the mixture for landing in the event that you need to make a go around. I'm not suggesting that a go around is caused by pilot technique, rather because an animal or airplane may be on the runway.
Blue skies, tail winds and safe flying!
Sparky
I am curious what you think. Personally I generally set the mixture at run up for the given conditions (density or elevation,etc) and go from there. Whats your thoughts on leaning for take off? How about at 8000' and higher? It may seem like a silly question as the answer to me is pretty obvious, but think about it for a minute. Adjustments with the mixture are critical for engine life and performance. The second half of that is what I am really concerned with for this question imparticular. Performance. Getting the most out of your plane on a really short, high elevation or high density alt., airport.
Obsessed with learning....
AKT
