JP256 wrote:Or you could try this $99 Belite Radiant Pocket Radio: http://www.beliteaircraftstore.com/radiant-pocket-radio
I think it's pretty slick. (No relationship with Belite other than as a satisfied customer.)
losbright1 wrote:We have one of these in the Club Hangar..
https://www.sportys.com/pilotshop/air-s ... upttm.html
kg wrote:JP256 wrote:Or you could try this $99 Belite Radiant Pocket Radio: http://www.beliteaircraftstore.com/radiant-pocket-radio
Can either of you describe the difficulty of programing frequencies? Are either of these simple and easy to use?
I had a handheld iCom that I was going to use in the hangar but it was so difficult to program that I gave it away.
I feel your pain with the ICOM hand held... When I went looking for one, I tried basically everything out there at the time. The only one I could reasonably operate (do most functions) without referencing the user manual was the Sporty's SP-400, so that's the one I purchased. It's been great, and I'm glad I made that choice. (I'm also glad I bought it, since I've had to use it three times due to COM failures, two of which were in the DFW Class Bravo airspace...)Use the tuner buttons to increase or decrease the frequency. A very short press advances one channel spacing; a short press will cause it to scan for the next active station. A long press speeds things up.
Honestly, tuning is a trick, especially in the AIR or VHF band. It takes some practice to easily tune a station. That’s why the MEMO channel saving function is helpful – you can skip tuning.
