I am a former army officer in Australia working on a project in outback Australia . As part of this project we need to be able to lift ATV's and associated trailers etc (seperated if needed) in a single engine or light twin STOL aircraft, has anyone done this or is it the opinion of the forum that I might have more chance of forming an intimate relationship with Claudia Schiffer (gives my age away that doesn't it)?
The dimensions of the ATV are LxWxH of 211.4 x 120.9 x 128.9 cm, weight approx 350KG and the vehicle needs to be able to load without a forklift to lift it on (ie drive on).
My initial thoughts were an AN-2 could do the job (Polish built to get round the experimental cat), however, the door is just a fraction to narrow and as it's a monocoque/spar construction widening the door might be an issue, though we do need upwards of 6 units.
Perhaps a Turbo Porter might do the trick, though I have a feeling the body is to narrow, ideally what I need as a rear clamshell door loading light twin or single or alternately an aircraft that has cargo doors that open both sides to allow the ATV to be moved into position.
I'm trying to avoid the C-212/medium lift aircraft as they will not be economic, the same goes for the beloved chinook of my former life.
Thanks in advance for all and any help.
Best, Flyinggibbon
