Backcountry Pilot • location ITT SENSOR TSIO-520
3 postsPage 1 of 1
Hi guys , According to the attached diagram, does anyone know where the ITT sensor would be installed?
we do not understand where it is placed, on the exhaust side as I indicate in the photo with red or on the top side where I indicate in blue.
Sin título.png (29.05 KiB) Viewed 664 times
patrokop offline
Aircraft: Cessna 180-H 1965
Re: location ITT SENSOR TSIO-520
It is close to where you have the blue dot.
Exhaust comes out of the cylinder into the collector then goes into the turbo where there is a flange. The probe according to the diagram goes 1-2” upstream of the flange where the collector bolts to the turbo.
Your blue dot looks like its too far upstream.
TangoFox offline
Keep the Greasy side down!
Hi Tangofox , thank you for response!!!
best regards
Patricio
patrokop offline
3 postsPage 1 of 1
