CamTom12 wrote:Props are a 3d airfoil.
I'm not a quantum physicist but I'm fairly certain everything in the physical universe (not considering time) is three-dimensional.
Regarding static thrust prop measurements, I'm not sure I would make that the defining determiner of propellor climb efficiency or choice. It's better then no data - but the prop is not screwing itself thru clean air (relatively speaking) as it would moving the airplane forward.
My first trip into the Idaho backcountry I was standing next to my instructor at some strip, don't recall which one - probably one with food, and as we saw rafters go by and watched a plane take off with its prop noise reverberating against the canyon walls, I commented something like "I'll bet those rafters don't like airplanes". Without missing a beat my instructor said "Airplanes are part of the backcountry experience. They bring in clients, food, supplies, help and rescue".
Prop length. Last year I talked with all the Cessna 185 STC prop holders for McCauley, Hartzell, and MT. They all provided information about their STC.
Steve Knopp of PPonk, and Donna Jones of Davis Aviation were the only ones that started the conversation by asking what my mission was and whether I'm on floats, wheels, or both. They provided great information, while the others were just trying to sell me their STC propellor.
The short of it (pun not intended) is the longer blades will get off the ground quicker and climb faster, but cost as much as 4 knots cruise speed.
The longer blades will also perform better at high altitude (like above 10,500 feet). Steve told me his PPonked 182 which he uses as his prop test bed, when fully loaded, climb deteriorates significantly at 10,500 feet with an 80" 3-blade, but goes to 12,500 before significant deterioration with an 86" 3-blade. If memory serves I think the load was sky-divers.
Steve also told me that although he hadn't tested it, at even higher altitudes he believed the 86" would be faster in cruise then the 80". I can see how the extra drag of the 86" would be lessened to a point where the extra thrust of the 86" could give a greater cruise speed then an 80".
I'm still flying the 86" 2-blade seaplane prop.
