Backcountry Pilot • Looking for a tailwheel fork, and some operating tips
8 postsPage 1 of 1
I took my 3200 Scott/AB tailwheel apart to service and paint it, and found that the part of the fork casting that holds the compression spring in has broken off. I also found three spacers in the slot, while the drawing only shows two. It was rebuilt in Oregon before Alaska Airframes bought them.
Not sure what to do, I'd like a Baby Bushwheel, but I guess I am looking for a regular fork in the meantime. If anyone has one for sale please email me at [email protected]
Maybe I'll just use this as an excuse to get the BB.
I'd also like some basic tailwheel care instruction. Could I have done this by pushing the plane backwards and the tailwheel unlocking? I have done this a couple of times backing away from a fuel pump, and it makes a nasty bang. I guess I should have been unlocking it in a forward direction and then pushing backwards, but I was lazy.
Any help appreciated.
Re: Looking for a tailwheel fork, and some operating tips
Sutton Aircraft Salvage has always been a great source for finding used parts. Give Dave a call or email.. He might have what your after. Prices are reasonable.
(907) 745-6969
[email protected]
akgreg offline
Aircraft: Yes
I've owned/maintained 5 different tandem TW AC over the years with Scott 3200s and always push backwards with TW doing a 180 like you're describing with never your problem. I don't think it is your procedure. But, my AC were all lighter tandem planes: American Champions to Super Cub.
Just OH'd our Champ Scott 3200- parts from Univair and the new tension springs were slightly too large so used old springs. Works fine. They are kind of complicated little units.
Jack
flyingjack online
Aircraft: Husky/T206H
I have a standard fork I would part with but I won't be back at my hangar until the end of the month. If you are still looking then, let me know.
I also push the plane backwards with that loud "snap" when it unlocks. I haven't had a problem doing that but I dunno... maybe it's not good for it.
kg offline
Aircraft: Cessna 180J
If I can help you easily get one to you from the US, let me know. I could always meet you in Lynden. Sorry for your troubles
jugheadF15 offline
Contributing author
Thanks John, these really are 1st world troubles!! I should come down and fly with you though.
"I have a standard fork I would part with but I won't be back at my hangar until the end of the month. If you are still looking then, let me know."
will do, but I think that Akgreg's advice of Sutton is going to work out, Im talking to Dave later and he says he has one.
Thanks for the help.
I've got a mailbox in Blaine you can use. I usually go down once a week. Let me know if you want to use it.
Allan
albravo offline
FWIW a replacement standard fork is $340 from Airframes Alaska.
A wide fork kit with a baby BW is $1145,
or considerably less with a glider tire.
https://www.airframesalaska.com/Scott-3 ... fk3200.htm
8 postsPage 1 of 1
