Normally the fuel pressure is steady, but I noticed that both old and new pump occasionally fluctuate between about 23 (or 25) and 27 PSI. If I apply the electric boost pump, then I see the pressure rise to about 28 or 29 PSI and the fluctuation reduces, but there is still a small fluctuation. It can keep doing this for hours. Other times, the pressure will be steady for hours on end, I can't say why.
Can anyone comment on possible causes? Should I be concerned?
I thought I saw a thread about this issue somewhere recently, but I can't find it.
Fuel pressure is measured at the outlet of the engine driven pump.
Fuel pump is a certificated part / installation.
