Manual Flaps Cessna 206
I've searched some on the internet but haven't found an answer yet. Are there any Cessna 206 models with a johnson bar/manual flaps? I really enjoyed the manual flaps on my straight tail 182.
TxKiger offline
256
- Aircraft: 182
Nope, not that I am aware of.
2093
Double post, sorry.
G44 on Mon Nov 16, 2020 7:00 pm, edited 1 time in total.
2093
Dang, thank you for the quick replies!
TxKiger offline
256
- Aircraft: 182
No, and you don’t want to go there, for many reasons. The best reason is if you learn to work those electric flaps, they work REALLY well.
10515
I can't imagine the amount of torque it would take to pull those big flaps on. They work just fine with electric, and I really haven't found the need for manual of them. Just set 20 for takeoff and go.
5186
Good to know! Thanks guys!
TxKiger offline
256
- Aircraft: 182
FWIW, years ago in a 206 that was set up for off roading, we bootlegged a push button flap retract on the yoke. It let you keep a hand on the throttle and still get the weight on the wheels to shorten things up. It helped.
flyingzebra offline
479
- Aircraft: Cessna Skylane 182 N3440S, Aviat Husky N2918L
flyingzebra wrote:FWIW, years ago in a 206 that was set up for off roading, we bootlegged a push button flap retract on the yoke. It let you keep a hand on the throttle and still get the weight on the wheels to shorten things up. It helped.
That's quick and easy on floats to shorten up landings---just reach over and flip the flap switch to "UP" as you flare......NO float in ground effect. Easy on wheels too, one of the benefits of electric flaps, actually.
10515
