tom
zero.one.victor wrote:Has anyone built one of these (Zenith or Savannah) with tailwheel gear? Seems like a natural.
Usually 912 powered, eh?
Eric
Eric
what putz puts himself into a situation where a full power 60 degree bank is necessary and a 45 degree bank won't work. If you're in that position you're gonna get what you deserve and I for one won't shed a tear.
a64pilot wrote:what putz puts himself into a situation where a full power 60 degree bank is necessary and a 45 degree bank won't work. If you're in that position you're gonna get what you deserve and I for one won't shed a tear.
The problem with your scenario is people get in trouble when a turn becomes necessary because the airplane won't climb out of harms way at full power and vx airspeed. I would assume that the decision to turn is rarely made while at cruise airspeed and power while in level flight. From what I can tell, both Sparky's and Berks accidents were the result of a stall from being behind the power curve. No violent manouvers are possible then, you just don't have the energy to do so.
mtv wrote:BM,
What I described (and please note that I stated a 50 degree bank, not 60--and that is within the Commercial PTS, by the way) is SPECIFICALLY NOT a violent maneuver.
Go out, at a safe altitude and GIVE IT A TRY, before you make statements like that. Then try it in a canyon. THAT is what I advocated. Every degree of additional bank will get you around quicker, but if you are afraid of your airplane, just stay out of the mountains, would be my advice.
I don't fly Bonanzas, so I'm not an expert on them. If I flew one, I'd give this technique a try.
If it makes you happy to only use 45 degrees of bank vs 50 degrees, so be it, but don't call a procedure that is well within the Commercial standards "violent".
Darwin was apparently correct--to a point.
a64pilot wrote:BM,
I wasn't saying anything about weather with Sparky's accident. I believe it went something like this. They got into a descending air mass that the aircraft didn't have the performance to fly out of, The Acft owner made a turn into rising terrain, Sparky took the controls at some point and tried to turn downhill, but some one stalled the Acft, Sparky dropped the nose to keep from crashing vertically. At least that is what I read, it may or may not be fiction, I don't know. The point is that there wasn't enough excess performance available for a high G turn of any type at any time once they realized they were in trouble.
I don't know anything at all about Berk's crash, but I would bet money that the 172 he was flying also was in a position to where there wasn't energy available for any high G maneuvering there as well. If your escape plan involves executing a high G maneuver to get out of a canyon, then I don't believe you have a good plan.
If conditions exist that can get Sparky in over his head, then conditions can exist that can get me in over my head, and I would say you as well, I am one of those people that believe that "except for the grace of God, there go I"
