Bonanza Man wrote:Good luck with that. One error in your proposal. Montana does have a mandatory ethanol program. It just hasn't kicked in yet. Once an ethanol production plant gets built in the state and is able to produce xx gallons a year, and I forget now how many millions of gallons that number is, ethanol is required to be put into mogas. We(MPA) fought this a couple legislatures ago. All we ended up with was an exemption for gas intended for aircraft and some other trivially small users.
>... The one here in Montana is a long way away and may be shelved.
These plants just don't make any economic sense right now.
I've got a one ton 2000 chev van with the 454 engine, and it has consistently gotten 12 mpg in cross country driving at 9500 pounds gross weight. Lately, with 10% ethanol, it still gets the same.
180Marty wrote:Savannah-Tom wroteI've got a one ton 2000 chev van with the 454 engine, and it has consistently gotten 12 mpg in cross country driving at 9500 pounds gross weight. Lately, with 10% ethanol, it still gets the same.
Thanks for posting---it's nice to know I'm not the only one that hasn't had such a negative experience as most. I know of at least one airplane that doesn't seem to mind 10% also. The person doing this thinks the carb ice issue isn't a problem anymore also. Anybody know of a lab test to confirm the theory.
I don't believe the fuel you use would make a significant difference on carb ice. While evaporating fuel will cool the air stream a little, I don't think it is enough to make much difference. The atmospheric conditions would probably swamp the fuel effect.
By being a branded FBO, we are covered under a $50,000,000 insurance policy
lowflybye wrote:>...
We just heard that TN has a state mandate that all auto stations must convert to selling 10% blend by January 2009...guess we will not be running auto fuel in the Maule any longer...the TN government needs to refund our cost of the STC.
180Marty wrote:>...2000 Buick Le Sabre with 3800 V-6 running an E30 blend. ...
