I'm wondering about cleaning precautions following ashfall.
I found some cleanup-related threads through the Alaska Volcano Observatory page, including
this one. If you search around there is a page specific to cleaning up airports, but it does not have much on GA aircraft specifically.
Some suggestions include not blowing anything with compressed air at greater than 30 psi, using copious water, changing air, oil, and water filters often, using electronics at a bare minimum, and keeping everything under cover as much as possible. If you are cleaning up ash, it's best to dab, not wipe- with a damp cloth. If deposition gets to be very heavy, then structural tolerances come into play also.
We have only had trace amounts of ash so far in Denali, but it sounds like it could be headed our way, and it sounds like others of you are already into it. On the day that I first noticed it here, I cleaned my plexiglass windshield with copious amounts of warm/ hot water (it was a little below freezing). I did not use soap, although later when I was cleaning the car I noticed that a little soap seemed to help in getting the ash off- it was really sticky stuff- static electricity, maybe?
I installed my canopy cover and cinched it down tight. I left the wing covers off on purpose because I have mesh covers, and I figured getting ash under the mesh would be an invitation to serious abrasion. I also tightened down the cowl cover. Hangaring is unfortunately not an option.
Yesterday it snowed 6", and I attempted to leave a thin layer of snow on the wings and fuselage so that if more ash falls, it might act as a buffer, and I might be able to sweep the ash off without it directly contacting the skin of the airplane.
Curious what others are doing or have heard. Good luck to all those who are in the path,
Denalipilot
