Backcountry Pilot • Need a little help transferring waypoints from garmin to gar
11 postsPage 1 of 1
My dad's 296 quit picking up satellites, so he reset it. Picks up the satellites, but lost all the user waypoints. :roll:
So, I go to map source and receive all the waypoints from my 496 and sent them to his 296. Now mine are gone. #-o So, I try the reverse and receive from the 296 and send to the 496, nothing changes. :(
What am I doing wrong?
Thanks Gary
shortfielder offline
Re: Need a little help transferring waypoints from garmin to
Bonanza Man offline
Bonanza Man
Thanks
I downloaded the ezgps. Put both gps's in the program. Pulled the waypoints off the 296, but am unable to send them to the 496.
Any thoughts?????
Gary
Still have all my waypoints on my dad's 296, and can't get them back on mine. What am I missin?
Is there another way to transfer. I've tried map source which has worked fine in the past, and easygps.?????????
Gary
Gary, do you get an error message from EasyGPS? Or does it quietly fail?
Can you export your waypoints from EasyGPS to a common file format? If you do, perhaps someone else can try to send them to their unit to confirm your data is good.
What are your settings in the 496 for Serial Data Format (Menu > Setup > Interface) and Transfer mode?
Perhaps do a manual delete of all your waypoints in the 496 prior to attempting the upload (Menu > Points > User + [Menu > Delete All])
The app I use is GPS Babel. Perhaps try it if nothing else works. I've only heard good things about EasyGPS so I don't imagine it's the app.
Hey Z
I recently sent my old 496 to Garmin for repair/upgrades/battery. This is a new unit, apparently easier to send me a new one than fix the old one. When they did, they would not transfer my 5 years of waypoints :evil: , but I had given most of them to my dad so I was able to retrieve them back from his.
Then he had to reset his because of being unable to receive satellite signals. Doing that,he lost his user waypoints, so I was trying to put mine back in his which went fine, but in doing so, I lost mine, and am now trying to get them back from his.
Maybe they are just getting wore out running back and forth :?
No error message
Settings SDF=Garmin Data Transfer
Transfer Mode=Host
I had a couple user waypoints in there, but I have deleted them now and will keep trying. I will try the link you sent me.
Are those settings cool??
Thanks Gary
When I do the receive from the 296 w/the easy gps I get my list of wasypoints on the left side of the page, and it looks like it has put the on a map on the right side of the page.
Yeah those settings are correct.
Can you export or save your waypoints to a Garmin .GDB file? Garmin .MPS file?
If so you might be able to use GPS Babel to get these formats into your 496.
Download the program, install it.
Select your input file.
Select your output device (Garmin 496, must be plugged in to be selected)
Configure any filters or options.
Send the data.
Thanks Zane for trying to help.
That stuff is a little too technical for me. :? I'll just put em in by hand.
Have a good one
Gary
Hey
Was going to check the settings on the 296. Under the settings heading there is no tab for interface. Where would I go to check the settings for this, and should they be the same as the ones in the 496?
Thanks again Gary
Just so ya know
I got my waypoints =D> Life is good.
Probably had them all along. I was looking in the wrong place. I was looking in nearest/user, thought they would show up there, but at home with no antennae, I guess not.
I started to put them in manually and when putting the first one in, it said it was already there.
So, I think I then went to direct to/user, and there they were, :D :oops:
So thanks for the help.
Later Gary
11 postsPage 1 of 1
