Backcountry Pilot • Need help with AWB2500 on a 170B
7 posts • Page 1 of 1
Have a friend with a 170B and he has a set of AWB 2500's with it. No paperwork and missing some parts from what I understand. ANyone have a copy of the paperwork I could forward to him. Thanks!
Re: Need help with AWB2500 on a 170B
AWB retractable wheel skis are approved on the type certificate. Only thing required is a logbook entry signed by the installing mechanic, and a revised weight and balance. Reference the TC for the 170.
Here's the pertinent part of the TC:
Specifications Pertinent to All Models (cont’d) Landing Gear (cont’d)
170 170A170B *(f) Federal AWA 2500 wheel-ski, Federal Instln. 78 lb. (All Models) dwg. 11R395 (Eligible with mechanical conversion on ground only) Note:Weight and balance of aircraft shall Retracted Extended be checked with ski in retracted and (+20) (+24) extended position. Not eligible with Item 202(c) installed*
(g) Federal AWB 2500 wheel-ski, Federal Instln. 102 lb.(All Models) dwg. 11R549 (Eligible with hydraulic conversion Retracted Extended on ground and in flight) (+14.5) (+18) Note:Weight and balance of aircraft shall be checked with ski in retracted and extended position. Placard required: "Do not extend or retract skis while in motion on the ground."*
(h) Federal AWB 2500A wheel-ski, Federal Instln. dwg.108 lb.(All Models) 11R549G (Effective on ski-gear shipped prior to Retracted Extended January 31, 1952) and 11R889 (Effective on ski-gear(+14.5) (+18.5) shipped after January 31, 1952). (Eligible with hydraulic conversion on ground and in flight) Note: Weight and balance of aircraft shall be checked with ski in retracted and extended position. Placard required: "Do not extend or retract skis while in motion on the ground."
Here's a link to the TC: https://rgl.faa.gov/Regulatory_and_Guid ... Rev_55.pdf
If you need drawings for the skis, you might give Wipaire a call. They do have some of the legacy ski paperwork, but the only REQUIRED paperwork is the logbook entry and w/b.
WWhunter wrote:Have a friend with a 170B and he has a set of AWB 2500's with it. No paperwork and missing some parts from what I understand. ANyone have a copy of the paperwork I could forward to him. Thanks!
PM me with an email address.
I have them on my 170B and have all the necessary installation paperwork.
AKclimber offline
Thanks Mike and AKclimber! I just spoke with him and I guess it is the assembly/parts info he needs. He obtained the skis and a box full of pats but has no idea how it all goes together. I believe he is/has contacted Wip to see if they have any of the old drawings and parts break down. He hasn't heard back from them yet.
Thanks again!
The ski parts expert at Wipline has been on extended leave for health reasons from what I’ve heard. I wish him well. His knowledge is missed.
Sounds like the rest are working from home so responses have been slower.
Pinecone offline
WWhunter wrote:Thanks Mike and AKclimber! I just spoke with him and I guess it is the assembly/parts info he needs. He obtained the skis and a box full of pats but has no idea how it all goes together. I believe he is/has contacted Wip to see if they have any of the old drawings and parts break down. He hasn't heard back from them yet.
Thanks again!
Tell him to get in touch with Steve Kracke at Atlee Dodge in Anchorage, and see if Steve can give him some assistance. Steve rebuilt my AWB 2500s from the ground up, and did a great job. Been some years, but.....
And, then, tell him to BUY some stuff from those guys, assuming they help him get things sorted out.
I have these on my 1955 170B with the hydraulic version. I can provide pics and assistance as needed. Email me with your needs: Nielsen at Bloomer dot Net.
john54724 offline
John Nielsen
Co-Owner
www.Flight-Resource.com
