Need PDF of Skywagon 74-85 IPC
Tue May 15, 2018 12:56 pm
Does anyone have a PDF of the 74-85 Skywagon IPC handy? I have the book, but am looking for the PDF. Thanks.
Greg-
2339
- Aircraft: C180H / C170B
www.avthreads.com
Sent you one attached to an email
Barnstormer offline
2700
- Aircraft: C185
Should we post it here in the KB?
2855
I'd love t have a copy. Gladly make a BCP donation for one.
Cannon offline
282
- Aircraft: C-185
Piper J3C-65
Pitts S1S
Zzz wrote:Should we post it here in the KB?
I think that is a great idea. How do I do it, just send to you?
Barnstormer offline
2700
- Aircraft: C185
Thu May 17, 2018 10:08 pm
Barnstormer wrote:Zzz wrote:Should we post it here in the KB?
Yep! Zane@
2855
Fri May 18, 2018 10:42 am
I have pdf's of the 1953-62 C180/182 IPC, also the 1961-73 C180/185 IPC.
Also the Continental O-470 IPC, as well as the O-470 maintenance & overhaul manual.
Also a pdf of the A185F owners manual.
And while I'm at it, also pdf's of the Narco Com 810 & AT-155 manuals.
Any of those desirable for the KB?
10534
Fri May 18, 2018 11:18 am
hotrod180 wrote:I have pdf's of the 1953-62 C180/182 IPC, also the 1961-73 C180/185 IPC.
Definitely.
2855
niente qui
dogpilot on Mon Aug 03, 2020 9:00 pm, edited 1 time in total.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
dogpilot wrote:Well, I did a bunch of scans as well for the 185 and 206. The big issue is the ones I made are huge files (35-200mb), made to print high quality hard copy. I can put them on disc and send them in, I would die waiting for them to upload.
1976 A185F POH
1976 A185F Cessna Pilot Normal and Emergency Checklists (suitable for printing on cardstock)
185 Service Revision 7
185 Parts Manual
IO520 Overhaul Manual
206 Service Manual 1977
206H Parts Catalog
206H Maintenance Manual
206H NavIII G1000 Manual
206H G1000 Quick Reference
Lycoming O-IO 0540 Operators Manual
G1000 Maintenance Programming
206 1977 Parts Manual
Lycoming OH Manual
WX-500 Manual
KX-155 Install
Garmin 430 Installation
Garmin SL-30 Install Guide
Aspen EFD1000 Intall Guide
Garmin GTN-650 Installation Guide
Garmin GTX-330 Install GuideP&S 8000BT Install Guide
Various 206H Checklists
That's awesome. Thanks James. Will PM you with address if you want to put on a disc.
2855
Mon May 21, 2018 11:50 am
I started adding these to the Knowledge Base page for the Skywagon. More to come.
https://backcountrypilot.org/knowledge- ... umentationClick on the "documentation" tab.
2855
Thank you to all involved.
Flying Dave offline
210
- Aircraft: Aviat Husky
