Hey guys. I am having issues with oil pressure on my 80 Hp 912. the problems I'm having are way out of my league and Im completely exhausted for ideas.
would love some input from experienced rotax owners on what they feel the problem may be and/or what action I should take from here. I will be calling Rotax Australia on monday but Im super stumped. I typed up a rundown on whats been going on but feel free to ask any questions.
Before works
The electronic oil pressure gauge would typically run showing between 150 – 200 KPA (21.7-29 PSI). this is low however the previous owner told me they replaced the oil pressure sensor and not the gauge and they said this was as a result of the new sensor not being properly matched to the gauge and that the oil pressure was ok.
Works completed.
Following the issue with my muffler the following work was completed (note, the muffler was patched up for me to fly home and the oil pressure was fine then, the variations in oil pressure has arisen since the following works were completed)
1) new exhaust installed and mounted differently
2) Carbys balanced
3) oil and filter changed
4) new Oil hose installed between radiator and what I believe is the return (comes in right below the bleeder)
during the test flight the pressures seemed normal but after 10 – 15 minutes the oil pressure started to gradually decline showing on the electronic gauge as low as 100 KPA (14.5 PSI)
I was advised to try 1 of 2 things. Replace the bleeder spring and ball (was found not to be done from the original AD) and that the issue is likely electrical so try fitting a capillary gauge.
After replacement of bleeder
so the new bleed spring, ball and screw fitting were changed. We ran the motor after this and it showed on the electronic gauge around 220-250 KPA (31.9 – 36 PSI). However when I reved the engine it would increase directly proportionally with throttle to as high as 350 KPA (50.7 PSI)
I took it for a flight about the airport and a circuit but after a matter of minutes the oil pressure started dropping when at idle and got as low as showing 50 KPA (7.2 PSI), It had never come anywhere near that low before. I got it back on the ground ASAP and we fitted a capillary gauge.
at idle the capillary gauge showed 50 PSI however when I revved the engine it got as high as 90 PSI at 5000 RPM. It is worth noting though the from 5000 – 5600 RPM the Pressure didn’t change, it remained at 90 PSI. I havn’t taken it for another flight since in fear of doing damage.
Intended further works
Right now my only plan is to try another Capillary gauge to insure it isn’t faulty. With both the electronic and capillary gauge showing a fluctuation I know there is a problem there, the question is which one is showing the right range of fluctuation. If a second Capillary shows the same numbers I know the electronic gauge is definitely out of sink.
