Zzz wrote:Or, by posting the info here, the answer will be waiting for the next person with this question.
hotrod150 wrote:Be advised that not all 170's are the same. I measured the arms when I did the W&B on my old ragwing 170 some years back and was glad I did, because the factory W&B sheet numbers were not correct. Mine had C180 gear legs which swept forward more than the stock legs, plus a 3200 tailwheel which puts the wheel on the ground farther aft than the smaller Scott t/w which was standard equipment. FWIW I still have that info: the mains were at 18.5" (stock was 22"), tailwheel was at 249.5" (stock was 249).
hotrod150 wrote:There's two different C180 gear leg configurations, I had the later ones which are 3-1/2" farther forward than the stock 170 legs. The early C180 legs (1953-54) are not swept as far forward, I believe those are only about 1/2" farther forward. There were two or maybe three different 170 gear legs, but I think they all had the same rake.
Zzz wrote:
A&P IA's out there, the TCDS is the authority for W&B stations, correct?
EZFlap wrote:hotrod150 wrote:There's two different C180 gear leg configurations, I had the later ones which are 3-1/2" farther forward than the stock 170 legs. The early C180 legs (1953-54) are not swept as far forward, I believe those are only about 1/2" farther forward. There were two or maybe three different 170 gear legs, but I think they all had the same rake.
I think they changed the sweep on one of the 170 legs... That's why the early 170 legs are left/right swap-able but the later ones are not???
Zzz wrote:Also remember that the weights are only accurate if upper door frame is level.
182 STOL driver wrote:Got stations sorted out thanks - the stations for wheels is not on type data sheets - except for the fuel.
TCDS A799 wrote:Landing Gear
201. 2 Main wheel-brake assemblies, 6.00-6, Type III
(a) Goodyear Model LF6HBD 13 lb. (+22) (+22) (+22)
Wheel Assembly No. 511960-M
Brake Assembly No. 9521239
(b) Goodyear Model CL6HBM 30 lb. (+22) (+22) (+22)
204. Tail wheel assembly
(a) Scott Model 3-24B, steerable 5 lb. (+246) (+246) (+246)
*(b) Scott Model 3200, steerable, swiveling 8 lb. (+249) (+249) (+249)
installed in accordance with Scott Bulletin I-168)
*(c) Maule SFS-1-2-P8 6 lb. (+246) (+246) (+246)
