On a recent flight back from Nevada in level flight @ 9500' my oil pressure dropped to 34 psi as my oil temp rose to 204 deg f. OAT was 30 deg f . This was a bit alarming as the sun was going down and landing options were limited. 20-30 mins later the temp went back down to 185 and the pressure climbed back up to 40-41 psi. Green is 30-60 psi.
Anybody had similar situation(s) and what did you do to resolve them? New EI gauge and I believe it's accurate. 20 hrs on rebuilt engine ECI cylinders good compressions, Not a non congealing cooler. I'm seeing the oil temp all over the place from 185-200 up and down. I'm suspecting the Verna-therm.
