mtv wrote:Most airplanes I've run that are in good condition use a quart of oil every ten to twenty hours. I have run one or two that used a quart every four hours, but that is starting to get excessive, in my opinion.
So, who buys the oil for these airplanes, and how do you determine where the oil is going? Sounds like you might want to tighten up some of your procedures to help you track this kind of stuff.
You can find overhaul cost estimates from several engine overhaulers. Depending on the engine model, frequency of use, etc, the engines may or may not go to tbo.
In working with the one flying club I was in during my career (and never again), propeller abuse may well be one of the most costly functions, again depending on the type of aircraft and where they are flown. If any of hte aircraft ever go to gravel strips, you'll use up propellers regularly.
Doing some reading, a quart every 10 hours is what I have read. We change oil every 100 hours, give or take. As the engine nears TBO, I believe it is changed every 50 hrs and the filter is checked for metal. We regularly are able to go over TBO on our aircraft so long as all the other vitals are looking good.
As for oil use, a case is kept in our club's shed. How it is supposed to work is when you take any out of the shed, you need to write down how much and what aircraft. It is also to be noted on the aircraft logsheet. With 90 members (less than half of whom fly), it isn't easy to keep tabs on it. Some record it, some don't, etc.
Thanks for the info guys. It's good to hear others experiences.
