NWS forecasted weather window is opening tomorrow, packing and planning to fly Arizona.
Good by to the dark November LZs of the coast:
I would love to meet you Rob! Thank you for the guidance.Rob wrote:The riding in AZ is almost endless. From your location you should be able to access the Arizona Peace trail lickety split. It will probably end up being a few day ride, and much fun.
It will also take you right past my home strip, as well as my work strip, where you are welcome to hang out and make airplanes make noise.
Or you can stop in in the Robbie if you find yourself out this way, and we won't even make you land on a dolly![]()
Several of the local gas stations here have racing fuel. I don't know if it's any better than avgas, and generally costs much more.
Take care, Rob
Thank you for the compliment! The fan is manual switch. The rider guesstimates what conditions the fan may be helpful. During hot slow riding I leave the fan running. The oil really stays cooler.SkylaneSam wrote:Pretty slick oil cooler setup on the front fender. I don't see those to often.
Do you control the fan manually or thermostatically?
