G44 wrote:YES! Change the oil. Lycoming recommends a tach time as well as a calendar time interval. Xx hours or 4 months, which ever comes first. These engines in most cases never wear out, they usually rust out, change the oil.
asa wrote:This is a timely topic for me so hoping to take advantage of the info. I will need to store an IO-540 for at least 8 months. It will be off the airplane but I can run the preservative oil through it before removing from airframe. I see Tanis sells a pickling kit for $270 with everything you need including dehydrator plugs and such and it meets the Lycoming SB instructions. https://www.aircraftspruce.com/catalog/ ... tanis1.php
I also see electric "Engine Savers" being recommended as an alternative.
https://www.aircraftspruce.com/catalog/ ... gsaver.php
It's $325 vs $270. Engine Saver could theoretically be used well into the future, so a little added value there?
Kurt, what are your thoughts? Baseline would be pickling I suppose. Engine will be indoors with 110VAC so power for engine saver is not an issue.
FARMAULE wrote:I would guess that a large majority of all GA aircraft often go 4 weeks or more without a thought or consideration on this matter. Four weeks can sneak up on the best of us. If I had to pickle my engine every time there’s a chance I may not fly for a few weeks I’d go broke just in preservation oil. I’d think if this is gonna occur on a common frequency one of the air dryers is your best bet. I do agree pickling is the safest bet but.....
pipeliner wrote:[This is why we should use Camguard.
Ross
StillLearning wrote:I have a hard time believing that a month is long enough to be a problem. While the longest I have gone without flying my 180 is 7 weeks, while it was in paint, I can't imagine pickling an engine every time it might not get flown for 4 weeks. 3 weeks of no flying has happened a few times, between work, bad weather, and other airplanes to fly, 3 weeks can sneak up on you pretty quick.
I think not helpful. Scrapes the oil residue off of surfaces without enough engine speed or oil pressure to re-apply said oil residue.PsychedelicWatermelon wrote:I've been waiting on a new Concorde battery for 3 weeks (supply chain) so I went to the hangar and swung the prop through about a dozen times. Helpful or not?
What Cam said. Definitely not helpful to turn the prop over.CamTom12 wrote:I think not helpful. Scrapes the oil residue off of surfaces without enough engine speed or oil pressure to re-apply said oil residue.PsychedelicWatermelon wrote:I've been waiting on a new Concorde battery for 3 weeks (supply chain) so I went to the hangar and swung the prop through about a dozen times. Helpful or not?
My plane has had a few unforecast stagnant periods (in a long one right now). I don’t touch the prop unless it’s with the starter with the intent to come to full operating temp.
