I learned a very expensive lesson with parking brakes as well, but in my case it was a very different lesson. The short version ; stopped on a sand bar on a cold morning, kicked back in the front seat eating munchies, I slid my feet back and under the seat. Kinda like sitting indian style. With big clunky boots on this locks the parking brakes on a cub. Prior to this I rarely used the parking brakes and always relied on chalks, so I rarely
really checked them prior to a departure. Ended up getting out and hanging around for quite a while, which was long enough for the brake brake fluid to get warmed up enough to pressurize the system some. The surface was sandy enough to mask the partially locked brakes, but they were locked enough to necessitate an abort. Aborting a T/O roll in a cub with the tail already in the air and the brakes inadvertently set is costly
another example;
A few summers ago a very well known experimental was running around with a few very well known north westerners, they were playing on glaciers and at some the pilot of the experimental locked the parking brake on the slopped ice. Even on 35's the T/O with locked brakes was a non event. Upon returning to the lodge, where there was no ice, the experimental A/C did a somersault on landing. It made it's way back to the lower 48 in a shipping container to fly again someday
Both myself and the experimental pilot still use parking brakes today. Our mistakes were genuinely ours, and while I can't speak for the other gent I can certainly say that in my case what I learned from my brake problem was that failing to properly use and understand our equipment does not constitute a failure on the equipments side. Since then I have set the parking brake in everything I fly, every time I park, unless prudence dictates otherwise. In any case I treat every plane I intend to move as if the brake was set prior to movement. Furthermore, since levers can be manipulated in flight, I also treat every landing as though the brakes have been set for the duration. To the poster who said GUMPS, BINGO. But don't just sing out a nemonic , do something about it, check and touch the gas lever, touch the brakes and gear, etc..
I find parking brakes far more valuable of a tool to leave off any airplane. They contribute less weight to an airplane than anything else that is so handy when you really need it. For me removing a valuable tool does not constitute a solution, and if the tool was poor in design I would prefer to seek a better thought out design. On a standard A/W cert. this might prove to be a challenge, but as an experimental there should be no reason to not build a system that works as you see fit.
FWIW, the Thrush I fly every night has the same Scott valves as my cub, and they get locked every time I return to the pad. This is an average of 20 times a night. We routinely get out of the airplanes to check mixes, maps, pee, eat, etc... During this time the airplane is normally getting hot loaded and / or fueled. Leaving a running A/C without parking brakes would be a no-no. This is in feathered Pratts, some would argue that leaving any running Garret is a no-no, I won't comment on that here.
I suspect this is far more cycles on the valves than the typical G/A airplane, but with standard maintenance they do just fine and do not exhibit any bad behaviors.
More food for thought...
