Backcountry Pilot • PBS TP100 Turboprop?
4 postsPage 1 of 1
Anyone know about this thing?
135lbs
241 HP t/o
214HP mct
If I’m doing the math right, 28GPH however.
https://www.pbsaerospace.com/aerospace- ... aft-engine
Re: PBS TP100 Turboprop?
Yikes! That's awfully high fuel consumption for the rated horsepower . Especially when an O470 will do better at 1/2 the GPH. That said...the TP100 is light. :)
darata offline
I get 24GPH at cruise. But it seems like high consumption considering my 750HP PT6A-34 does 56GPH on takeoff and 46ish at cruise. I've always liked the idea of a small turbine like that for some of out small aircraft but the amount of fuel you'd need to carry to have the same range as the original piston engines makes it almost useless.
This got me curious so i googled and found this:
https://www.kitplanes.com/turbine-powered-rv-10/
4 postsPage 1 of 1
