Part 91 Commercial Sightseeing Operators
Allowed to continue conducting flights under the operating rules of part 91 within the 25-statute-mile exception, except for flights over national parks, which are generally limited to a total of five per month.
Impact: No change from previous regulations
Must conduct passenger safety briefings on every flight and provide passengers with life preservers for over-water flights. Required briefings include the use of seatbelts, prohibition on smoking, exiting the aircraft, and use of life preservers for over-water flights. Passengers are required to wear the life preservers while in flight if the sightseeing tour is to be conducted beyond the airplane's power-off gliding distance to the shoreline.
Impact: Sightseeing operators who conduct over-water flights beyond the shoreline of an ocean, sea, lake, pond, river, or tidal basin will now have to purchase life preservers at a cost of about $200 per unit and an additional $200 annual maintenance and inspection costs.
Each operator must apply for, and operate in accordance with, a letter of authorization (LOA) issued by the FAA. The LOA application must include the following information:
Name of operator, agent, and any d/b/a under which that operator does business;
Principal business address and mailing address;
Principal place of business (if different from business address);
Name of person responsible for management of the business;
Name of person responsible for aircraft maintenance;
Type of aircraft, registration number(s), and make/model/series; and
An Antidrug and Alcohol Misuse Prevention Program registration.
The operator must comply with the provisions of the letter of authorization received.
Impact: Sightseeing operators could encounter lengthy delays in obtaining LOAs if they wait until close to the September 11, 2007, deadline before sending in their LOA application.
The FAA failed to specify in the final rule what the provisions of the LOA will consist of, which could lead to confusion and problems with some FSDOs.
Any sightseeing operator who has not been complying with the existing drug and alcohol testing requirements will not be able to get an LOA until after they register their drug and alcohol program with the FAA.
