I am building an experimental aircraft, a pusher, that will be a bush plane, using the highlander gear. The spot where a center mounted throttle quadrant should go is getting pretty busy and I have been considering moving the throttle up into the overhead, as in a Twin Otter. Having no experience flying with an overhead throttle I am looking for opinions and impressions for anyone that has. The flap controls are already in the overhead and would be right at hand, with no interference between the two.
What is it like to fly with an overhead throttle?
-M3X
