The only time an aircraft has too much fuel on board is when it is on fire.
SIR CHARLES KINGSFORD SMITH
But how do you ensure the valve stays closed especially when the ferry tank is not installed?
whee wrote:..... I'll have about 100gal between the main tanks and this ferry tank.....
whee wrote:Thanks guys. I recognize that this tank isn't great and honestly I'll probly never use it but I still want to get everything ready for a ferry tank in case I ever use one.
I'll have a dedicated bung added when I add the return line bungs.
hotrod180 wrote:whee wrote:..... I'll have about 100gal between the main tanks and this ferry tank.....
That's about 9 hours endurance burning 11 gph through your IO-360.
Are you planning a lot of long trips?
I can see thinking that 50 gallon (4-1/2 hours worth) wing tanks maybe isn't quite enough, but I wouldn't go this route. Is there room for slightly larger wing tanks?
If not, I'd just live with the 50 gallon limit.
RockHopper wrote:I know this is going to sound condescending, but seriously put the aux tanks in the wing where they belong on the CG. Gas in the cabin is an accident waiting to happen. Ferry tanks used for long distance oceanic legs are a sparingly used solution that is a fairly high risk operation flown with a single crewmember. I realize that you're on a budget, but you really need to loose the "cheapskate mentalitiy" before it bites you in the ass. You need to approach Bush aircraft system design with an attitude that the worst possible scenario will eventually happen most likely sooner than later. The homebuilt community is littered with the fatal wreckage of aircraft that bulders tried using repurposed/substandard parts. I'm speaking from personal experience and have buried many fellow pilot friends.
mtv wrote:
And, where you gonna put that bear proof Yeti cooler with all the beer?![]()
whee wrote: 50 gallons will be fine for pretty much all my trips which is why I'm not installing the 11gallon aux tank in each wing that many builders install. Only time I see myself wanting more fuel is for a trip to AK or Mexico or the Bahamas.
