dogpilot wrote:You kind of have it backwards.
Not actually. The axial tensile stress on a properly finished is at or just below the yield stress. They aren't Play Doh. They become springs when they are bucked due to Poisson's ratio. The difference in use (shear vs tensile) depends on the designer. They are designed for bearing critical loads or slip critical loads. The load transfer for the bearing critical joint is the same as for a bolt...the fastener in such a case never sees shear stress as long as the friction load transfer is not exceeded. This means that the river (or bolt) never sees cyclic shear unless.the friction load transfer slips (as in a lap or butt joint). No fatigue of the rivet. This design goal is very, very important in aero applications. It is simpler to analyze and more reliable if proper riveted design and execution are possible.
The slip critical design uses the simple (well, not quite so simple biaxial stress analysis) shear forces as a naive conservative approach where skill or other concerns are to be expected. In fact, a lot of riveted steel structures default to this standard because of variability in real execution. In fact, civil structures standards move to bolts to be able to apply dependable preloads on bearing critical applications or use a slip critical design with rivets.
So it depends.
Even now, things that go fast and go boom boom very often take advantage of the efficiency and reliability of bearing critical design in riveted designs, if they use rivets at all.
A Boeing design manual covers this in more detail. It is often a young engineer's first encounter with bearing critical design. It means a lighter, stronger joint.
So yes, the rivets can be looked at as little clamps.
To your point about being weak in tension, yes...rivets have little strength perpendicular to the plane of a lap or butt joint.
In college, I had the privilege of getting paid $5 an hour to run tests on riveted joints with composites for weeks. The yield numbers for bearing critical designs were higher than the shear strength of the rivets alone ...by up to around 30% more than the naive shear area would suggest, and cycle failures were up to orders of magnitude higher for bearing critical designs, attesting to the bearing critical vs. slip critical differences.
If the load is not transferred to the spar due missing rivets, the load will be higher on the surrounding rivets, obviously.
