Fri Dec 09, 2016 11:04 am
Those techniques are used whenever possible but, at the end of the day, you're trying to make a slow enough pass to give a guy with a shotgun the best window to hit a running coyote--and even the best pass is nothing more than a snapshot. You're always riding the razor's edge between conserving as much potential energy as you can in both altitude and airspeed to convert it into the turn when you come off target, versus slowing down and flying low enough to actually have a chance at the target in the first place. Those two objectives are almost always at odds, since an extra 5 mph or 20 feet agl makes a big difference in being able to turn around or outclimb rising terrain, but also makes a big difference in terms of getting an effective shot. Easier to do on flat ground, where terrain is not a factor and you can make a pass from any direction and factor in wind. Harder to do when the terrain dictates a one-way solution, harder still when the wind and the terrain dictate opposite one-way solutions.
I'm definitely not trying to compare it to the complexities of hunting targets on the ground who can shoot back--I've got nothing but respect for you guys who do or have done that. In its own way, though, predator flying is one of the most dynamic/close to the ground types of flying out there, other than the low level aerobatic and/or Red Bull type guys. It's different from crop dusting in the sense that everything happens spontaneously, and all of a sudden. It doesn't take much of a lapse in concentration for things to go south in a hurry.
