prop for 0290
Fri Nov 25, 2016 12:46 pm
I just picked up a project with an 0290 for it. It is experimental and I am wondering if anyone has flown a cub or pacer type plane with the 0290 and what they may have used as a climb prop. Its a pretty high drag airframe so I don't care about speed, just the best take off anf climb performance I can get out of it.
akavidflyer offline
521
My Murphy Rebel has an O-290D2 and I'm currently equipped with a Warp drive 4 blade with nickel leading edges and tapered tips. Takeoff in 200', climb at 850-1000 fpm and cruise at 115mph at 2400 with 8.50's. The 31"s knock off a little bit on each of those numbers. It's a 69" prop running about 12.5 degrees (I think). Static RPM was set around 2300 if I remember correctly.
What kind of airframe do you have it on and which pistons do you have?
Timberwolf offline
193
- Aircraft: RV-6 with Glass and too much power
Murphy Moose M-14
I'd call Catto and tell them what you have and what you want. They NAILED the O-290-G prop on my buddy's W-8 Tailwind.
WorkingWarbirds offline
92
- Aircraft: Champion 7GCBC
Mooney M20E
Globe Swift
