steve wrote:The width of my farm strip used to be about 1/4 the size of yours and it was plenty wide. It is hard to tell from a picture if there is any change in elevation down the length of your strip, if there is (and depending on your soil types) I would suggest installing a perforated drainage tile about 60 cm under the surface, the entire length of the strip (just off to the side of where you would normally land), providing there is a place to outlet the water. If if you have anyone that installs drainage tile in your area this would be much more desirable than using gravel, as it would dry the ground quickly and no prop concerns as with using the gravel. I you are handy, have access to a backhoe and laser, or transit, you could do it yourself. I used to have a drainage business, feel free to ask if you have any questions.
Steve
GumpAir wrote:You're not going to hurt anything in an aircraft engine with occasional bursts of full throttle operation, or conversely, suddenly pulling it back to idle. It's been my experience that the harder you run 'em, the better they do and the longer they last. I think the stats show overwhelmingly that engines that have been babied have way more problems throughout their lives, and are way less likely to reach the recommended TBO.
And, like Contact says, for short field operation, your engine/prop is another control to use to get you to the specific spot you want touch. If you don't use it you might as well be flying a glider. Just chop the throttle at downwind and coast every time. Doesn't work real well, and THAT is hard on engines.
Zzz wrote:Ever flown with Greg Miller? He's not afraid of the short burst, like blipping the throttle on a dirtbike. It's amazing how just a half second of 1200 rpm can make a difference. It's usually in the final moments before touchdown though to make the spot, whereas sustained power is more appropriate above 50 feet for the glide slope.
GumpAir wrote:Combine throttle with ground effect and it's amazing how much you can slow down before touching the ground.
